Any idea what would have caused these shingles to crack like this?
They are about 5 yrs old. Fairly consistent over whole roof surface (north and south facing) Pitch about 3:12 No attic venting apart from perforated soffit Thanks, Last edited by pwigle; 11/28/07 at 2:31 PM.. |
If they are surely 5 years old it certainly is a manufacturers defect, they look like 25 years old shingles..........
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
How well was the attic ventilated?
'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
I would not be so quick to call these manufacture defects. Defects yes but the actual cause may not be certain.
These look exactly like what I have seen of "weather exposed storage" prior to delivery or installation. Materials act differently in their packaging than when they are exposed/installed to the elements. Pallets upon pallets are sunbaked and condensing in packaging, rain soaked, frozen... for days, weeks, months... are then delivered may linger onsite exposed longer and then installed Looks OK from the ground until the contractors tail lights disappear but in a short amount of time they look like what's depicted If you have a local "real lumber yard", Habitat for Humanity or surplus store go look at the yard stored shingles, I'm sure you'll find some broken bundles to observe. I'll try and get over to the RR distribution yard and get some pix is it just me or is the inspect-ny.com site down??? i haven't been able to click through for about 2 months now ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 11/8/07 at 7:08 AM.. |
i haven't been able to click through for about 2 months now-- badair It's just you Barry!! 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Myth Two is that attics need to have lots of ventilation. Again, venting requirements are not based on rigorous scientific research. TenWolde explains that attic venting originally arose as a moisture-control strategy for cold climates. Other purported benefits, such as longevity of the shingles, arose later. It is widely believed that increased attic venting will prolong the life of roofing shingles by cooling them. But research shows that venting has very little, if any, effect on shingle temperature. The most important issue in shingle temperature appears to be the color of the shingles. Light-colored shingles reflect sunlight and don’t get as hot as dark shingles. One possible real benefit of attic venting in climates with large snowfalls is to reduce snow melt on the roof to avoid the formation of ice dams. But according to TenWolde, a more effective——and energy-efficient——way to control snow melt in almost all climates in the United States would be to use air barriers and insulation to prevent heat from entering the attic. |
I've run diagnostics and my system says it's not able to make the connection at their end. Are you running IE, Firefox or ... ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
They appear to be baking from improper ventilation. |
http://www.inspect-ny.com/roof/AsphaltFailures.htm works fine for me, in IE and Firefox. |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Bring some actual "tested" rather than anectdotal information from the masses to the debate that attic ventilation has anything but a small effect on shingle life. Did you follow and monitor, over their life, the shingles shown in the last picture on the above part of your site......and have another roof with the same shingles, same orientation, same slope with ventilation next door......if not, it's defintely not scientific but anectdotal. And we all know about anectdotal stuff believed and heard on the street....... Remember the 1980's when just "gay" people got and spread aids?? I have referred the board to a picture of a research roof of shingles with the same shingles both vented and unvented with no visible difference to be seen. Why does no one comment on that? A picture may be worth a thousand posts. There is more research available on the web> |
Did you ever go into an un-vented attic in mid-July and feel how hot that cavity is? And you wonder why shingles fold as they do in an un-vented situation. |
dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have run across this exact cracking pattern. The shingles were manufactured by Certainteed. Two of the house had leftover shingles in the garage with the paper still intact. Both Certainteed. I have seen it on several roofs that were from 6 - 4 years old. Every roof is the same color and pattern. Collingwood, Wasaga Beach, Barrie and Alliston Ontario area. One person actually has Certainteed rep onsite to look at them. He said they would last the regular life of the shingle and offered no othere advice. No other buyer even addressed it when I advise them they need to monitor them closely and replace them at any time it shows signs of leaking. I tell the buyer I cannot even begin to estimate how long they may or may not last. On almost all the houses had adequate to good ventilation. It was not the issue. All you can do is note it on you report and advise the client the life may not be the average life of the shingle. That is all you can do. Last edited by dcook1; 11/8/07 at 12:15 PM.. |
I see your in Ontario...if those shingles failed because of poor ventilation I'll kiss everyones ***** here that even mentioned the possiblity...... Between cloudy skies and 6 months of decent weather, there is NO way in hell those shingles failed simply because of poor ventilation. For one thing they don't look like 5 year old shingles to begin with, but if they are, they are defective. I've seen them installed in Arizona with attic temps reaching 175 degrees 9 months out of the year without ANY ventilation and Never saw any shingle manufactured in the last five years fail because of poor ventilation....manufacturer defect yes....heat...NO. I have measured the surface temperatures of shingles here, over 200 degrees many times of the year. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
| Comp shingles over wood shingles | Matthew Hopkins | Exterior Inspections | 28 | 10/16/07 12:19 PM |
| Cracked flue tile | bknowlton | Inspecting HVAC Systems | 6 | 2/2/07 12:37 AM |
| 3 tab shingles curling | ccbrands1 | Exterior Inspections | 8 | 1/29/07 6:25 PM |
| Cracked Heat Exchanger | jallingham | Inspecting HVAC Systems | 26 | 5/11/06 11:12 PM |
