Old 12/27/08, 9:09 PM
Carl A. Brown's Avatar
Default Cracking FAUX STONE
Old 12/27/08, 9:16 PM
Stephen W. Stanczyk's Avatar
Default Re: Cracking FAUX STONE
Carl,
Are you sure that isn't a faux crack to make it look real?
Stephen Stanczyk
Old 12/27/08, 9:18 PM
It might be an expansion joint.
Old 12/27/08, 9:21 PM
I posted them over HERE but not much chatter yet.
Old 12/27/08, 9:25 PM
gbeaumont's Avatar
Lemmee guess, that cracking is right below that piss-poor excuse for a kickout flashing. right?
Wanna bet that the corner cracked due to swelling of the substrate
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 12/27/08, 9:28 PM
What kickout flashing?
Old 12/27/08, 9:34 PM
gbeaumont's Avatar
well come on Carl at least they lobbed a bit of tin in there, it's not like they weren't trying
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 12/27/08, 9:37 PM
Trying to do what?
Those are baby tins and around here that is all they use.
There is no way for a cladding installer to get the proper clearance from the roof no matter what the cladding.
Old 12/27/08, 9:43 PM
gbeaumont's Avatar
Trying to do what?
I guess they've never heard of Dryflekt up there, mind you I doubt that the stone had proper clearance above the roof counter flashing anyway
Gerry
(Mark B Adams)
NACHI02121106
Old 12/27/08, 9:47 PM
O they have heard of Dryflekt I made sure of that my self.
Old 12/28/08, 12:34 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
DRY what??? Just kidding.
Old 12/28/08, 2:51 AM
"Typical cracks noted in the decorative stone. Keep these well sealed at all times and monitor in the future to prevent moisture penetration and deterioration, etc. Unless the wall cavity is opened up, there is no way for the inspector to know if there are problems -- such as trapped water, wood rot, mold etc. -- inside the cavity. Also, there is no good way for us to know what part(s) of the cavity(s) should be opened up for further evaluation. There could be an important problem - - or there may be no problem at all. There is no economical and easy means for the Kansas home inspector to be sure one way or the other in a visual, non-destructive home inspection".
"However, in Kansas since we now have mandatory E&O insurance and at least $10,000 worth of liability for unfound defects on each inspection, the inspector recommends having a licensed geo-technical engineer with stone masonry experience RIP the stuff off and look for defects - PRIOR to leaving the inspection contingency period".
__________________________________________
GOSH - this is gonna feel really good next year when the new Kansas law goes into effect. Watching the face of the commissioned RE Agent who has not had a sale in 2 months after I show them the stone and then make my profound comments AS ABOVE to keep myself financially solvent.
Old 12/28/08, 7:49 AM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Ouch!! We have a Licensing and Gen Liability requirement and I thought that sucked...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 12/28/08, 9:50 AM
This link here might be found useful for this subject on faux stone, other than explaining why the crack.
http://www.culturedstone.com/technical/flashing.asp
Marcel
Old 12/28/08, 9:54 AM
Barry Adair's Avatar
you guys know this but worth repeating for those that don't...faux stone will only perform as well as the substrate it's adhered to...if the underlayment is moving or cracked this will telegraph though the stone veneer and appear on the surface...when applied at or across dissimilar material intersections and solidly attached to both systems expect cracking to occur, that outside edge/stucco abutment requires no more than a backer rod w/high grade low modulus caulk seal... and was probably not treated with the respect she deserved
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Faux Stone! The next EIFS! cbrown1 Exterior Inspections 35 2/18/09 8:51 PM
Faux stone siding lfoster Exterior Inspections 15 11/5/07 8:40 AM
Expansion/ contraction joints jlybolt Structural Inspections 13 5/31/07 7:03 PM
