This being such a common issue. I just wanted to compare how you report on cracks and what recommendation you offer.
Thanks |
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Depends on the size of the crack and is the cause known. Too many factors not enough info...
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
To me it depends on the size of the crack and the age of the driveway.
Many times I write typical settlement cracks, keep an eye on them; or the driveway needs to be repaired. |
Also, depends on size/depth, can be trip hazard.
Other than that I couldn't think of a reason to mention it.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I always mention to seal cracks to prevent further deterioration from freeze/thaw cycles. (I am in Ohio, ice is that stuff you use to cool your drinks down there in Florida)
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Ditto. Other statements if its spalling, raised by tree roots, or just generally deteriorated.
Good info... InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Mr.Strump.
I will ask you what type of driveway First. Tar-mat ( asphalt ) or cement. Tar-mat or asphalt. 1: How long are the cracks and how wide do they separate, and where are the separations in proximity to ground compaction if any?.( depressions ) 2: When they separate ( cracks ) do they have any compression imprints,( due to water infiltration and frost heave in climate is cold. ( zone 6 or lower ) or car weight compaction. Near trees because rots will work there magic, and I can go on. That's a good starting point for asphalt. If you see no compression ( ground deviation or bumps) convex or concave impressions, and the driveway is smooth and sloped towards the street then it is acceptable. You might recommend sealing if you notice to many cracks for they will open up and let water and allow frost heaves. Most driveways are acceptable and look on Google or ask inspectors for reference material. Cement is another story but similar in detection methods. There should be expansions cuts to accept movement all ready in place. You will look for spalling, cement surface waring away irregularly and agrogate is showing on the cement. You will look for all the same evidence as tar-mat ,cracking ,length of cracks how wide do the separate. Again its objective to guess and you need examples. INCHI has completed inspection reports that have been used by myself for reference. They are inexpensive and I suggest you turn you eyes that way. I purchased them and they are an excellent tool to help you with your report writing. I hope I was helpful and hope you enjoy your new vocation as a home inspector. Good luck. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
The cause of cracking...
Just a lot of "common" minds... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Thanks for the info - most all of the driveways here are concrete and almost always have at least less than a 1/4" crack.
Thanks - great info on how cracks are formed. What suggestions do you recommend to your clients, I usually tell them to fill with masonry caulk or comparable crack filler?
You are asking questions without giving specifics as Mr.Shepard pointed out.
What are they caused from Mr.Strump. Any relations to Donald Strump. Just joking. I had to. It is dependent on the nature of the damage. I myself do not tell clients about how to repair things I do not know and practice keeping my mouth closed anyway but that's me. I just started inspection as a certified residential build inspector ( that should get 1 member going ) and have a restoration company also. So conflict of interest. I am or should say was an apprentice cement finisher but I got tired of looking at my feet and being on my knees. Same as roofer 12 years plus. 1 more trade but no need for that. Mr.Shepard pointed out some keen observations you should be looking at to understand whats going on, and why they ( the drive way ) is cracking before you suggest repairs. ( just my opinion and I am new ) Read your SOP again and see if it helps. Good luck and call me if you want. ryoung7 Read Mr. Shepard's observations and note them.Might get you some feathers in your cap. Thanks for coming back. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
I had one , 1/2 mile long driveway with Large settlement cracks . yes i reported it Because of the cost to fix it. about 300 feet (new Home). The cost to repair will mean ripping up and re pouring. Normal cracking is also mention to seal cracks to prevent water damage.
| Basement Waterproofing,new driveway etc | john bubber | Structural Inspections | 0 | 9/26/09 5:31 AM |
| Driveway Cracks | lagudo | Exterior Inspections | 7 | 5/5/08 11:35 AM |
| slab no cracks: Brick veneer cracks | gkoehl | Structural Inspections | 1 | 4/17/07 4:52 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
