How far would you go?
I made a little platform and got my camera in. Last edited by jkogel; 12/22/08 at 5:24 PM.. |
The first one looks dry enough to give her a go, but the second one... Nope.
The pic you took would have to suffice, "inspected from the entry"... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
I don't think so.
sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Getting in is one thing. Getting back out is another. I'd have done what you did. "Crawl space access is extremely limited. This area of the home was not inspected, and no representation is made as to the conditions within it." You might recommend additional hatches be cut in closet floors for future evaluation.
Stu |
[You might recommend additional hatches be cut in closet floors for future evaluation.
Stu[/quote] Now that's something I hadn't thought of. Good idea in this case. |
Standing water? No thanks!
Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
John
No Thanks, No Way, etc. I usually list it as inaccessible due to height, access, and possible unknown environmental hazards/conditions. I usually recommend having a "Foundation Professional" inspect and determine existing conditions, and recommend remedies for those conditions, prior to any final decision on the property. I've seen and recommended the addition of floor panel access in a closet or utility type room area in the past, but often I've found that the access still is impossible if the joist are so close to the ground that you still can't get down and through the opening and between the joist and the ground. I've only seen a few that bad. |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
A good point made in an earlier post, always consider the exit back out. You may be able to get in, but how quick could you get out when that rabid raccoon comes at you when your in the far corner.
You mean to swim or not to swim??? I took a taste to make sure it wasn't sewage.
Jusssssst Kidding. I didn't go in. I could see a big crack in the cast iron waste pipe from the crawl space access. Peter Doane Realty Check Inspection Service NACHI ID# 05120681
found a ptretty good site, don't have time to check for others:
http://www.ccohs.ca/oshanswers/hspro...ace_intro.html |
I would think the size, age & health of an inspector would also determine if they would enter the crawl access area.
Crawls are like roofs: Easier to get in & on then out & off |
| Return air from crawl space | WHI | Inspecting HVAC Systems | 11 | 1/9/12 8:43 PM |
| Crawl space in under house | dnasser | Structural Inspections | 15 | 2/27/07 8:12 PM |
| Is Romex in a crawl space a problem? | jtedesco1 | Electrical Inspections | 48 | 9/30/06 11:53 PM |
| Manufactured home crawl space | sstanczyk | Structural Inspections | 2 | 2/19/06 5:23 PM |
