Old 11/15/07, 9:05 AM
Peter C. Russell's Avatar
Default Crawl space venting?
Can anyone tell me if a crawl space with a concrete slab that is under 100 sqr. feet need venting.
I looked in the code book and it says 1 sqr. foot per 150 sqr. feet.
Old 11/15/07, 9:07 AM
Roy D. Cooke, Sr's Avatar
Default Re: Crawl space venting?
The latest trend is to no longer vent crawl spaces to the out side and I agree with this trend . .
.... Cookie
Old 11/15/07, 9:08 AM
Roy, do you know if there is a code for this in the IRC?
Old 11/15/07, 9:25 AM
Sorry I do not and I do not think we use the same codes .
http://www.fpl.fs.fed.us/documnts/te...entilation.pdf
One of many that do not recommend Venting .
.... Cookie Canadian OBC 9.32.2.1
Old 11/15/07, 9:30 AM
Thanks Roy, good article
Old 11/15/07, 9:32 AM
Banned
Peter:
Sometimes we have to challenge the code with newer research and the code guys with tact!! Most codes allow for innovation or else nothing would ever change. Sometimes though, it's hard to affect change if the code folks are not up to the newest research.
See:
http://www.advancedhomeenergy.com/Fi...ot_to_Vent.pdf
http://www.buildingscience.com/bsc/
http://www.housingzone.com/article/CA6253710.html
Old 11/15/07, 9:48 AM
I'm with you guys, here's my problem, I am building a 10X10 attached breezeway with a 28X24 garage and the building inspector red flagged the crawl space. I have to talk to him but I would never put vents in something like this, plus, when I frame the floor I install 1" rigid foam insulation between the joists then fiberglass, then the sub-floor. Once this is sealed, and by the way we poured concrete for a slab, but once this is sealed why would you need venting?
IRC states 1 sqr. foot per evry 150 sqr. feet, my interpretation on that is anything under 150 sqr. feet does not need venting, per code.
Thanks for the help, when I talk to him I'm going to push the issue.
Old 11/15/07, 10:09 AM
Print off a couple of the sheets listed above and give them to him so he too can learn.
Give him directions to this BB (http://www.nachi.org/forum) and tell him he is welcome to come on and see what a great group we are and would love to have him visit.
Let him know we love to trade information with all to help the industry . Even give him a copy of this letter so he too can see we really are an International association.
.. Cookie
Old 11/15/07, 10:21 AM
Unmoderated Guest
The IRC requirés ventilation unless the crawl space is conditioned, meaning insulated, heated and mechanically ventilated. Any crawl space under 150 square feet in area still requires one square foot of ventilation free area. Failing to ventilate the space, one way or the other, is simply asking for trouble, in the form of mold and/or structural decay.
Old 11/15/07, 10:25 AM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Peter,
Sounds like (as you describe building it) it's not needed...
another website that I like...
http://www.crawlspaces.org/
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 11/15/07, 10:36 AM
Sorry I am on the other side of the fence have seen more mould in vented crawl spaces in my area then unvented .
I recommend to all my clients that I think and from what I have read Crawl spaces are better left unvented to the out side .
... Cookie
Old 11/15/07, 11:14 AM
Banned
[quote=Richard A. Hetzel]The IRC requirés ventilation unless the crawl space is conditioned, meaning insulated, heated and mechanically ventilated. Any crawl space under 150 square feet in area still requires one square foot of ventilation free area. Failing to ventilate the space, one way or the other, is simply asking for trouble, in the form of mold and/or structural decay.[/quote]
Richard:
Read the stuff from Advanced Energy. They found lower RH's with a properly prepared space. Why would we vent?? to make it wetter??
This new trend has been running through researched results not anectdotal based sections of code for 15-20 years now!!
Old 11/15/07, 11:19 AM
rwand1 rwand1 is offline
Have seen too many crawlspaces vented to exterior that had more problems as a result.
Not venting is the way to go.
Old 11/15/07, 12:15 PM
Andrew MacDonald's Avatar
Andrew MacDonald Andrew MacDonald is offline
Treat the crawl like a basement. (you wouldn't leave your basement windows open, would you?)
Andrew MacDonald
MacDonaldPropertyInspections.com
InsightThermalDiagnostics.com
ITC/FLIR Certified Building Science Thermographer
ITC/FLIR Certified Level 1 Thermographer
Old 11/15/07, 1:32 PM
Well my site contractor told me that the red sticker meant it was OK, first time with this inspector, so I told him to forget the vent and back fill it.
I'm on the side of not venting.
Return air from crawl space WHI Inspecting HVAC Systems 11 1/9/12 8:43 PM
Crawl space in under house dnasser Structural Inspections 15 2/27/07 8:12 PM
No Crawl Space Ventilation dmccormick Structural Inspections 11 2/5/07 11:34 AM
Strange Duct in Crawl Space jfunderburk Structural Inspections 3 1/11/06 1:02 AM
