| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
What are the requirements for a curb on an access door from an attached garage to a house? Would gas vapors potentialy enter the home?
Are furnace vents allowed in the garage? Wouldnt there be the potential for C/O to enter the home thru the ducts? |
dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Definetly mark this on your report as an immediate repair. That duct is a killler waiting to strike. Also, does the door have a self-closer? Is it sealed well around the door frame? Is the weather-strip good? Check all these. |
Here curb not required from garage to house.
As David said that duct is not correct. "Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
This has been discussed before. Although it is standard practice, there is no code for the garage floor to be lower than the house (at least not in the IRC).
Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
A change in floor elevation between house and garage may not be required by code, but it is still considered good practice. A minimum of 6 inches lower than the house floor is a good idea.
I would think any duct which passes through the garage wall should have a fire damper at the wall, and it would be best if it had no outlet in the garage. Code is a minumum requirement. Good practice frequently exceeds those minimums. |
I spoke to the building commissioner pertaining to the curb, supply register & auto closure.
There is no code for the curb. There was one at one time. There is no enforcement of the auto closure. It is advised to install as a good practice. Supply registers are allowed in the garage if they have proper fire ratings. There needs to be a 20 minute damper installed and the pipe needs to be of proper thickness. Return vents are definitely not allowed. Anybody have any links or information on the 20 minute damper? Thanks |
03 irc R309.1.1
http://www.lorient.com.au/Literature...20seriesv2.PDF ____________________________________________ "An Education, not just an Inspection" Larry Kage Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond. ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
This is a product from Australia. Are there local products available? |
| Newbie here with a slab "standards" question | Robert Young, #3 | Structural | 17 | 4/10/07 11:48 AM |
| Garage Door Safety...No Reverse...Advice Please | gliebig | Exterior | 33 | 3/17/07 8:28 PM |
| Bad Door and Water on the Floor | jnicholson | Exterior | 7 | 10/4/06 10:45 PM |
| Stained steel Door .. HELP | rcooke | General Inspection Discussion | 11 | 9/7/06 10:56 PM |
