I'm looking for verbage to write up, letting the owner know that,
there is a concern about snow and rain, getting into these vent stacks. do these cut off vent stacks look like a problem to you? |
| Find an InterNACHI certified West Virginia Home Inspector (and anywhere else in North America) |
Yep, It's a problem. If the stacks are PVC then the expansion and contraction factors are not going to work with these "boots". Cold days and Hot water in the DWV will make that vent stack move and possibly open up the "seal" at that boot and just may allow moisture / snow/ water in the attic area..
Six inches from the roof surface is the minimum and 10 inches in cold climates to prevent frost issues / blockage |
Steven, why did you break them off?
10" or 6" above projected snowfall, some jurisdictions may vary. Check with AHJ for your area. Up here we need 4' LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks guys, I will make them aware of the height they should be, and why.
Actually, I just tripped over them while I was up there, and they broke off thanks again, |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 9:17 AM |
| Vent stacks | wsiegel | Exterior Inspections | 8 | 3/26/07 11:09 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
