Old 10/24/09, 2:00 PM
Default Damaged (warped) Vinyl Siding
Any ideas as to how this siding became warped or damaged. This is the rear of the home just above the basement walk-out. I usually come across this type of warping when the homeowners have placed a grille to close to the siding and the heat from the grille warps the siding.
However, that would not be the case here, and it seems odd to have that warped siding in this location. Another odd thing is the so called "shield" on the right side of the window adjacent to the damaged area. It looks like it was put there on purpose.
Any suggestions?
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Find an InterNACHI certified West Virginia Home Inspector (and anywhere else in North America)
Old 10/24/09, 2:12 PM
Bruce A. King's Avatar
Default Re: Damaged (warped) Vinyl Siding
Reflections off the glass can do that, also some vinyl siding that has been painted a darker color will warp.
http://www.cardinalcorp.com/data/tsb/ig/IG15.pdf
www.BAKingHomeInspections.com
704 301-3207
Old 10/24/09, 2:16 PM
Wow, great info!
Thanks Bruce.
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
Do you unzip vinyl siding? apfaff Exterior Inspections 13 7/23/08 9:49 AM
Composite siding with paper thin vinyl wrap wohara Exterior Inspections 1 5/19/08 10:38 AM
Composite Concrete siding Issues I need Help rkie Exterior Inspections 13 5/1/08 8:27 PM
ALCOA vinyl siding one side warping, why? Lynn Kelly General Inspection Discussion 4 5/23/07 5:32 PM
