Happy Thanksgiving to all of you,
Wondering if this is called damp proofing, or something else? Should it not be re-secured where it is warped? Thank you in advance. |
| Find an InterNACHI certified North Dakota Home Inspector (and anywhere else in North America) |
I think it is called something else but.
Don't look like it is doing much good of anything. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
It is hard to tell what I am looking at but I agree with Marcel in that it doesn't appear to be doing much good.
Do you have a wider back picture? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Larry, look at the first pic again.
Is it possible that it is just a protective membrane? It appears to be black behind it that would almost indicate a bituminous asphalt base proofing. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Sorry I can't be more definitive but it is tough to see all the way to NC. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Yes, there was the black bituminous damp proofing around the entire structure at grade level. Just curious as to what the outer warped pieces are called.
grusk is a non-member guest and is in no way affiliated with InterNACHI or its members.
It is a fiber board used to help protect the damp proofing (or as it was called back then water proofing) when the foundation is backed filed. We used this on basement foundations back in the 80's through early 90's.
Gary |
Gary, should I recommend this be re-secured where it is warped?
Since the fabric is no longer needed for protection, but is hiding the black dampproofing, I would just recommend that it be repaired as required.
Exactly...repaired as required to maintain needed waterproofing integrity. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| AFCI in Damp Locations | krigler | Electrical Inspections | 8 | 11/26/09 10:27 AM |
| Is there anything code specific to water proofing or damp proofing? | bdoles2 | Structural Inspections | 2 | 7/16/08 8:54 PM |
| Damp corner in the basement (posted by Shayne Duquette) | AskNACHI.org | AskNACHI.org Inspection Questions Forum | 5 | 7/9/08 12:07 AM |
| Water proofing is peeling | jtroth | Structural Inspections | 8 | 4/6/08 5:51 AM |
| damp proofing foundation wall interiors | kshepard | Exterior Inspections | 13 | 2/28/07 9:04 PM |
