Old 10/15/07, 10:15 PM
scosta's Avatar
scosta scosta is offline
Please Note: scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Deck flashing question
Is it ever acceptable to attach the deck to the home without removing the vinyl siding?
The vinyl siding was not removed, the deck was butted tight against the vinyl and bolted directly to the home. No flashing.
Also, what is the recommended distance between lag bolts?
Thanks in advance.
Steve
Old 10/15/07, 10:22 PM
Carl A. Brown's Avatar
Default Re: Deck flashing question
Does this help?
http://www.flash.org/resources/files/HGCC_Fact23.pdf
Was there moisture barrier behind the siding?
Old 10/15/07, 10:39 PM
Peter C. Russell's Avatar
Steve, in short no. The vinyl siding needs to be removed, then the ledger board gets installed, then the flashing which should be copper so it doesnt react with the new treated lumber. Then the decking and then the siding can go back on.
I usually put 2 3/8"X3" lags with washers in every other bay.
Old 10/15/07, 10:42 PM
Joe Funderburk, CMI's Avatar
Originally Posted by prussell
...then the flashing which should be copper so it doesnt react with the new treated lumber.
Aluminum works, right?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 10/15/07, 10:43 PM
Not in my opinion. I suppose one could mount the ledger tight enough to crush the siding but it is not right.
Thanks in advance.
Steve
It depends on the loading.
See page 9 of this:
http://www.fairfaxcounty.gov/dpwes/p...ks/details.pdf
Larry Kage, CMI
231 929 3525
Old 10/15/07, 10:56 PM
Joe, A very big NO! aluminum flashing will react to the copper treated wood and the chemical reaction will break down the aluminum within months, this will cause the flashing to be ineffective.
Think of copper valley flashing, if you used a aluminum roofing nail to secure the flashing down to the roof it would start eating away at the copper within days. All or most pressure treated wood is now rated ACQ which is Alkaline copper and comes with the brand of Nature Wood, in my area anyway. You will find some treatments that uses Borate in it for pest infestation.
Old 10/15/07, 11:17 PM
I should also add that all fasteners that penetrate the copper flashing need to be copper as well, hope this helps.
Old 10/16/07, 12:21 AM
scosta's Avatar
Thanks everyone.
Carl thats a great reference. Thanks
Steve
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Question about chimney flashing waksell Exterior Inspections 16 6/26/07 1:25 AM
Deck flashing? wcruz General Inspection Discussion 1 7/21/06 11:37 PM
Deck Question nishanf Exterior Inspections 17 6/2/06 12:18 AM
