Old 2/3/07, 2:15 PM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Deck Install
pic 1 shows that the post is not notched to receive the front rim joist.
it should be notched the same as the rim joist on the right, correct?
Old 2/3/07, 4:43 PM
Default Re: Deck Install
Correct and the supporting joist should have the proper joist hangers.
Additional Simpson ties should be added to the post rim-joist connection.
Marcel
Old 2/3/07, 5:06 PM
A bolted connection, like that, would be limited by bolt capacity and is, usually, avoided. Here is an install guide that may be helpful...particularly pages 11 and 12.
http://buildingcodes.jocogov.org/doc...eck%20Book.pdf
Larry Kage, CMI
231 929 3525
Old 2/3/07, 7:50 PM
bandag bandag is offline
Please Note: bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thumbs up Re: Deck Install
Larry, that's a nice deck website, Thanks
Old 2/3/07, 9:32 PM
Christopher Rich Iii Christopher Rich Iii is offline
Chris.. Not deck related, however did you state you could not view the shed roof over the garage or did you climb on from the deck and view from there? Just something I see here that many inspectors do not comment on.
Chris
Christopher Rich
A Closer Look Home Inspections, LLC
609-802-2001
www.ACloserLookHomeInspectionsNJ.com
ACloserLookHomeInspections@comcast.net
Old 2/3/07, 10:16 PM
Chris
Roof was a bit too steep and it was only about 15 degrees, so I stayed off the roof.
I had to find a higher elevation near by and use binoculars to view the portion you're referring to.
i stated in my report that the roof was viewed with a ladder at eaves and/or the ground with binoculars.
Old 2/5/07, 9:51 PM
ccoombs's Avatar
ccoombs ccoombs is offline
Please Note: ccoombs is a non-member guest and is in no way affiliated with InterNACHI or its members.
Great catch! That is a small, but very important detail.
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 10:50 AM
Deck joist blocking/bridging jbancroft Structural Inspections 7 10/4/07 9:16 AM
Deck Question nishanf Exterior Inspections 22 6/2/06 6:41 AM
