Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 8/29/09, 10:43 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default Deck installed on grade
Is it a good or bad idea to install a vapor barrier underneath a grade/ground level deck?
Thanks!
Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America)
Old 8/29/09, 12:17 PM
GARY L. RUSK GARY L. RUSK is offline
Default Re: Deck installed on grade
Some contractors install plastic/vapor barrier to keep the weeds and grass from growing up through the deck.
Gary
Old 8/30/09, 8:51 PM
Peter C. Russell's Avatar
Doing this will trap moisture. The best method for installing a deck on grade would be to remove the earth in the area, lay down landscaping cloth, a bed of crushed stone and then the deck.
The cloth and stone will allow drainage and keep the weeds/grass down.
Old 8/30/09, 9:10 PM
David P. Valley's Avatar
Thanks!
No plastic under decks, please.....When it rains the moisture will now accumulate on top of this plastic and the deck structure will become compromised and will eventually rot away, because this concealed moisture accumulation will not evaporate quick enough.
Crushed stone is the norm in my area. This stone will always remain dry, because it drains.
Old 8/30/09, 10:18 PM
Linas I. Dapkus's Avatar
Linas I. Dapkus Linas I. Dapkus is offline
We put down landscaping cloth covered with stone for our new deck.
Old 8/31/09, 2:05 AM
Paul Pendley Paul Pendley is offline
So if thats the case....why would you also allow the raw lumber in a few places in the pic that I see be in contact with soil???
Paul Pendley
Premier Property Inspections
866-458-8516
Old 8/31/09, 9:08 AM
I took care of that with 1/4" chicken wire for separation, air flow and to keep critters out. Also installed deck boards to make it easier to get around on the deck.
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 11:50 AM
Check The Deck wdevries Canadian Inspectors 1 7/9/08 3:00 PM
Commercial Electrical Inspections jtedesco1 Commercial 29 1/12/08 6:03 AM
Max load allowed on 2x2 ledger bking Structural 4 12/23/07 3:05 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
