Hello,
Been coming across this faulty design more and more on decks improperly supported on the column. ![]() Correct is below. ![]() My question is on the call out. Would you call this a critical error? Been using -Family room (or deck) outer girder improperly attached to 4x4 support columns see photo Recommend review and repair by a Qualified Contractor Thank you, Steve Gaudet Inspections LLC Bedford, NH 03110 cell:603-714-8628 ..... <(©¿©)> NH Lic # 188, ASHI 250816, InterNACHI www.gaudethomeinspections.com |
| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
For what it's worth... this can be a local thing. I've seen areas where carriage bolts are OK for 2-2X's on either side of post is OK, situation/design depending. Maybe a quick call to local building and safety in your area?
If we were talking about a deck or balcony bearing on the first design, with live and snow loads.. I'd say it is a defect, or at least recommending the client verify the improvement was permitted, nearly every time. I'm fortunate that the typical approved designs in my area are available at the counters or online. |
If Improper, Note as Improper...
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
| Got a letter from ASHI's President today. | gromicko | General Inspection Discussion | 55 | 12/12/10 11:51 PM |
| Deck Failures | rcooke | Miscellaneous Discussion for Inspectors | 29 | 10/25/07 5:47 PM |
| Deck Question | nishanf | Exterior Inspections | 22 | 6/2/06 6:41 AM |
