Would you recommend a bottom STRINGER for additional support of this deck rail?
Thanks. Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America) |
A bottom board perpendicular to the balusters?...no, but check the riser gaps. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
No, but I would recommend a qualified contractor add a support beam and posts to convert this to a free-standing deck... as it is incorrectly connected to a cantilever. Major accident waiting to happen!
Bottom line is that there are tens of thousands of decks attached to cantilever'd sections like this. Though we may believe it is not ideal, it is fairly accepted practice in the industry. Not all states follow the IRC. Politics often play a part in adoption or acceptance of codes. A municipality may make a code requirement less restrictive. It is ultimately up to the AHJ. Even if your town has adopted the IRC, YOU are not the AHJ, nor are you a licensed design professional. So, not busting balls here... but what makes you legally qualified to evaluate a structural design, attachment, or component assembly. A home inspection is NOT a code compliance inspection. Many PEs have problems with HIs precisely for this reason. Many believe we are full of crap. So, while I may agree that, in theory, this is not an ideal design... you have stated that it is unsafe. We can discuss the validity of stating that the roof load is not directly transferred via pure vertical path of travel to the footings. We can state that the cantilever was designed to carry ONLY the weight of the roof. However, it would be rare that a deck collapsed from shear force at the ledger, as opposed to pulling from the rim joist. We can analyze and pontifficate all day. In the end, it doesnt matter. Only the opinion of the architect, engineer, and AHJ carries any weight. Last edited by jfarsetta; 6/16/09 at 10:25 PM.. |
This is what I say when I see that crap:
"The guardrail construction at the *LOCATION(deck/porch/balcony)* is unorthodox and we consider it sub-standard. The guardrail structure is composed of balusters only (1.5 inch x 1.5 inch lumber). We recommend the addition of substantial supporting posts of 4x4 lumber as a minimum at corners and other areas. Repairs should be conducted by a state licensed general contractor as deemed appropriate." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I know you do, as do I in my files, but Joes' link was faster to find.
What is the age of the home and the deck?
You have failed to answer the question. What makes you LEGALLY qualified to comment on ANYTHING of a structural nature. Nothing. Statistically, you cannot qualify your statement. Is the ledger bolted or nailed. Are joist hangars used or are the joists toe nailed and resting on a ledger. Are the posts resting on piers? Your statement is unqualified. Also, when referring to a building code, be sure and referece the applicable code in force at the time the structure was built. Your reference is from 2006. When was the dwelling and/or deck constructed? My suggestion is that you familiarize yourself with what the unlicensed practice of professional engineerng is all about. |
Missing rail posts: http://www.nachi.org/gallery/exterio...rail-posts.jpg
Girder-post connector seems to be missing:
Incorrect: http://www.nachi.org/gallery/exterio...-incorrect.jpg Correct: http://www.nachi.org/gallery/exterio...connection.jpg Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 |
The document Jeff referenced http://www.aohomeinspection.com/pdf/...kGuideDCA6.pdf and based on IRC is flawed in several areas. With regard to this thread, the IRC is flawed in their approved post connection on the top of page 16, Figure 25. A study conducted at Virginia Tech University by Dr. Joseph Loferski, and Dr. Frank Woeste, P.E. with Dustin Albright, showed that the post attachments on the top of page 16, Figure 25, even with numerous blocking details and even with metal hurricane brackets... all failed.
Due to leverage, a 200 pound force at the top of a rail requires almost a couple thousand pounds of resistance at the bolt or lag screws. Anyway, being up to code doesn't mean it is safe. Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 6/16/09 at 11:35 PM.. |
Nick,
My point is that, all to often, HI's spout a "defect" in the same manner as a structural evaluation. the comment he made was absolutely unqualified, as the poster is technically unqualified to make any structural determination. Have we forgotten "What's Really Important on a Home Inspection"? |
| Deck Railing | rmclennan | General Inspection Discussion | 9 | 5/22/09 5:08 AM |
| Check The Deck | wdevries | Canadian Inspectors | 1 | 7/9/08 2:00 PM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 2:05 PM |
| Deck stairs hand railing | dshaw1 | Structural Inspections | 3 | 10/16/07 7:10 AM |
| Wide gaps in outside deck railing | jbanning | Exterior Inspections | 6 | 9/20/06 6:56 PM |
