jchamp is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is notching the outer deck rim joist allowed? I don't think it is, but can't find any information to tell me yes or no. See attached picture.
Thanks. |
| Find an InterNACHI certified Virginia Home Inspector (and anywhere else in North America) |
The joint at the rim joist needs support but I noticed the the length of the joists seem long for their size. How big was the deck? Did it feel solid wen you walked on it? You may want to recommend an addition beam and posts be added to the center.
Appears to be a very long span without proper support.
That's NOT a rim joist, it's a BEAM!! And a splice like that is not permitted in a beam, and the sag you see tells you why. That beam appears to be 2-2x10, but effectively it's only a single 2x10, because the outer board has no structural value due to the splice.
I don't see a notch in the picture. |
Thought my eyes were bad as Rich must have meant splice. |
| Check The Deck | wdevries | Canadian Inspectors | 1 | 7/9/08 2:00 PM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 2:05 PM |
| Deck joist blocking/bridging | jbancroft | Structural Inspections | 7 | 10/4/07 9:16 AM |
| Frost, Ice, & Condensation @ RIM JOIST | Sean M. Jeric | Inspecting HVAC Systems | 4 | 2/5/07 6:56 PM |
