I'm going to be inspecting this house this week and was wondering about this deck. I don't like the look of it.There doesn't seem to be enough support for this deck. Shouldn't there be some lateral support to keep the deck from swaying? Sorry this is the only pic I have, got it from the listing. Any help would be appreciated.
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
| Find an InterNACHI certified Georgia Home Inspector (and anywhere else in North America) |
Sorry forgot the pic.
Don't walk on it! Unsafe in my view. Here's some guidance.
http://www.aohomeinspection.com/pdf/...kGuideDCA6.pdf “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I agree with Joe. I would have a SE look at it.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Thanks for your help. Joe, that is some good info you provided to me. One question of clarification, it states not to secure deck to veneer siding, are they speaking of all siding, vinyl, wood and in my case cedar shakes? Or are they speaking of brick only?
Except for brick, which they often drill right through, the exterior siding material should not be present at the area of attachment and flashing should be all that is between the ledger and the building.
If you can't see the bolts on the inside of the structure, I'd advise you to disclaim it as uninspectable. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
If you are referring to brick veneer, Joe, than you are incorrect...
Page 12, upper left corner Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Holly cow! That's scary.
Gezz guys Live on the wild side and add a hot Tub!
You fellows always safety safety safety lol |
Post better pics after your inspection. It looks like the support beams could be cantilevered into the main structure but its hard to tell from here.
www.MauiHomeInspections.com |
That's a possibility. I'll let you know.
I had that thought also, but decided against it. Close as I can figure, the deck is around 8ft x 8ft. If it is a cantilever design, than the support beams/joists would need to penetrate the structure approx 18 ft. Somehow I doubt that is happening. Possible, but doubt it. Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Finally did the inspection. Here are more photos of the deck. It didn't look any better closeup. Railings were loose and posts were toe nailed in. Very few lag bolts were used on the ledger board. I'll recommended a SE look at it. Let me know what you think.
Could this deck be cantilevered? The last photo looks like the joist goes into the concrete. Also, here is a photo of the railing post.
| Deck Support Illustration | vsantos | Exterior Inspections | 10 | 3/22/09 9:28 PM |
| Check The Deck | wdevries | Canadian Inspectors | 1 | 7/9/08 3:00 PM |
| Another deck Collapse | rcooke | Canadian Inspectors | 11 | 3/30/08 9:03 AM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 3:05 PM |
