Would you say these supports were proper for this deck? 4X4 post 2X 12 toed nail in? Large notch in ledger board.
Without more info, or pictures...
No, no, hmmm... no! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
I agree Jeffrey, no and no.
http://www.cbchomeinspect.com/upload...on%20Guide.pdf Start with page 7. Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
House is eight years old, in Johnson County, KS, it sure was not built to the Johnson County guidelines.
There are other acceptable post to beam connections besides the one on Page 7, so don't be thinking that's the ONLY acceptable connection.
Post/girder connection is poor, recommend correction.
I don't have a problem with the notch. Those are 1/2" lag screws through the ledger into the home rim joist. If they're on 24" centers, as is typical, it's not going anywhere. You could cut that ledger all the way through and as long as it had 2 solid lags supporting no more than two joists (and no point loads), it wouldn't go anywhere. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
The 2x horizontal support beam is not properly secured to the 4x4 posts to prevent lateral movement.
http://buildingcodes.jocogov.org/doc...eck%20Book.pdf |
| Check The Deck | wdevries | Canadian Inspectors | 1 | 7/9/08 3:00 PM |
| Another deck Collapse | rcooke | Canadian Inspectors | 11 | 3/30/08 9:03 AM |
| Illinois State Chapter of InterNACHI DECK FRAMING/CONSTRUCTION COURSE | ksitzes | General Inspection Discussion | 6 | 3/4/08 6:48 PM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 3:05 PM |
