Old 2/26/09, 12:15 AM
Joe Funderburk, CMI's Avatar
Default How do you flash this?
Did a 2 story home with a lower roof over the kitch. Lower roof meets the rear wall and at the roof/wall intersection there is a vent (like a ridge vent). How can you have proper flashing here if there is a vent? Anyone got any illustrations?
Photo is from on top of the 1st level looking at the vent. (FYI: there was no accessible attic space beneath the lower roof.)
Yes, there was a water stain on the ceiling below.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/26/09, 12:48 AM
Christopher Currins's Avatar
Default Re: How do you flash this?
Eliminate the vent, start over and and flash correctly.
Christopher Currins
Certified, Licensed
Old 2/26/09, 5:41 AM
Joe,
Check this out
http://www.roof-2-wall.com/
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 2/26/09, 6:47 AM
David P. Valley's Avatar
No...do not recommend eliminating the vent, as this is a newer vent that recently came out and I think it serves it purpose.
It appears to be a Cor-a-vent that was not flashed properly. Recommend flashing upgrade.
Old 2/26/09, 7:50 AM
You guys are great. Thanks to all!
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/26/09, 2:13 PM
OK, my bad. "Remove vent, start over and flash correctly".
Christopher Currins
Certified, Licensed
Old 2/26/09, 3:30 PM
klott's Avatar
klott klott is offline
Turn around and drop pants!
"It's not what you believe that matters...it matters what you believe!"
Old 2/27/09, 4:23 AM
Joe,
I would refer it to a GC to look at.....while those vents can work great, like any type of venting / flashing system, one must take into account the pitch.
As we all know, water can travel up hill (capillary action....negative pressure etc.) so even with a products such as this, they must be used in accordance with manufacturer instructions as well as realizing that such instructions must meet sound building principles.
I know from building homes over 30 years that not every product works as they say...........nor does some of the past logic used in coming up with building codes stand the test of time (house wrap...getting homes to tight, etc). Which is part of the reason our industry exists......things can go wrong even when instructions are follow.......any married man can tell you this........ lol
Again, I would simply call it out and let a knowledgeable GC (or manufacturer rep)
check it out.
regards
Jeff
Old 2/27/09, 10:32 PM
I referred it to a roofer. Said it likely leaks.
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/2/09, 2:52 PM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Want to bet the window isn't flashed? The window is the first red flag in vinyl siding. I recently updated a page on my website and it shows new work with plently of leaks built in,
http://www.albertsroofing.com/Window%20Flashing.htm
Old 3/2/09, 3:07 PM
I just updated the page again.
Old 3/6/09, 4:35 PM
Carl A. Brown's Avatar
I bet it is like Frank says and the problem is the moisture barrier and flashing under the window.
Old 3/7/09, 6:58 AM
Frank,
Nice site with great images. Thanks.
Here's a house I did yesterday.
One of many ways to send water behind your siding....
To flash or not to flash wward Exterior Inspections 2 8/29/08 10:55 AM
Arc Flash Information Only jtedesco1 Electrical Inspections 1 7/7/06 11:00 AM
To flash or not to flash? bgraham Exterior Inspections 4 5/16/06 10:26 PM
