I was chewed out by a builder for calling out vinyl siding which was installed directly over OSB. Vinyl siding obviously isn't completely watertight and builders seem to have a habit of not installing housewrap over OSB, especially at the garage walls. Does anyone else raise the end of a siding lap to see what it is covering?
Even though house wrap is required on most siding materials, I don't raise the siding to inspect for underlayment. Except at times, when my client's curious as to what material is installed on the underside of the outer siding.
I do a visual inspection of readily accessible areas only. |
The siding was gapped slightly due to improper installation so it was readily visible. I am just wondering if maybe I should start looking. What if the garage sheathing on an unfinished wall starts showing water staining in a few months. Does the fact that the siding (if vinyl) is easy to look under make me the loser if my client decides to come back on me for the rotting OSB. I know anyone can sue for anything and the OSB is not visible, but I just thought I would get some opinions.
If I see obvious signs of issues relating to the flashing, siding or it's underside, I'll investigate further as to the source, and if it requires lifting any accessible siding (without damaging it) in areas... I'll do it.
But to check under every siding you run into, is ridiculous and not required by any SOP. Your agreement should always cover you on any concealed areas. |
InspectorRiggs is a non-member guest and is in no way affiliated with InterNACHI or its members.
Whenever the builder "chews out" an inspector for anything, it should send up the red flag. If he stands behind his craftsmanship he shouldn't care WHAT you are looking at......
I think you have the right approach, if you see something and it leads you to investigate further which in this case is looking under the siding, then I think you are providing a good service to your client, would I look under all siding from here on out, no.
This is a big issue though, with today's practice of hiring subs to do all the work, for less money, they don't want to do some aspects of the job. IE. The framer gets $1.50 per square foot less than what he's use to, so therefore he does not want to put up the building paper as a means to make up for it, He says, it's the siders responsibility. The sider comes along and they make less money per square foot and he does a half %ss job of it or does not do all of it. Then, water gets behind the siding and the sheathing rots. Happens all the time. |
i glanced under a piece of siding sticking out to find everything wet & rotton...even though the disclaimer said the home did not have moisture.
YEA, right. i'm glad I looked. Michael Byrd Byrd-House Inspections Belpre, Oh |
You're right Peter, it does happen all the time. That is why I asked the question. Even though the SOP says you don't have to, I know that it is not uncommon for builders or siders to do that. Maybe I should lighten up and not worry about it but every time I see a vinyl sided house, I want to see what is underneath.
Whatever you do, do not lighten up, that's why your a good home inspector. You use your mind, experience and your sense's to do a good inspection. |
A tool is required for removal. This now becomes an "intrusive inspection".
Are you covered for this? If your report shouts "generalized non-intrusive, visual inspection" and your opening things up, be sure your wording is changed. I only look in there when there are water intrusion issues or when the client wants to know. I recommend you describe your method of inspection in the report. |
Generally the vinyl is lapped no more than 1 to 2". This means it's easy enough to lift the end of a panel and look at what it is covering. No tool is needed since the siding isn't unhooked from the panel below. If I can move a blind to look at a window, can I lift the edge on a piece of siding? Just a thought...
Yes I do. For several reasons. As a builder I constantly would catch my siding crew taking the felt paper home and not applying it to the house even though they had been paid to do it. On hardie siding this voids the warranty. Also according to the new energy codes this is now a requirement for any fairly new construction. Another note that is very important: If the house wasn't wrapped them most likely the windows aren't caulked or flashed. Even if you don't report on any of this it gives you insight as to how well the house was watched when it was built. Keep up the good work!
a mirror at the starter strip works well
never know what you may or may not find ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
- Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
| Asbestos | jlybolt | Exterior Inspections | 41 | 7/17/07 1:13 AM |
| Asbestos Siding | jwisecup | Exterior Inspections | 18 | 11/9/06 6:11 PM |
| Siding recall? | slarosa | Exterior Inspections | 1 | 10/3/06 1:11 PM |
| Lp siding | lagudo | Exterior Inspections | 3 | 7/13/06 12:40 PM |
