I know that just because you see a water resistive barrier behind vinyl siding, doesn't mean it exists everywhere. I know that.
But when you've confirmed that it's absent in many areas and likely absent everywhere, do you report it? Do you report it as a significant issue? What do you say are the potential consequences? Does the age of the home have a bearing on whether or not you report its absence? Inquiring minds want to know. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 6/16/11 at 12:37 AM.. |
| Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
House wrap is not a "vapor barrier". In fact, it is specifically designed to allow vapor to pass through it.
I report it, lack of eave protection / roofing felts too. The problem is, what is the recommendation? Remove all exterior / roof cladding to add, I don't think so.
I explain the purpose of the materials and the implications of them not being present, I sometimes recommend that they be installed when the cladding is replaced (if it's near end of life). Rick Strand, CPI CAHPI Associate Strand Home Inspections Inc. Calgary, Alberta, Canada Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Here's the 2009 IRC code: "R703.1.1 Water resistance. The exterior wall envelope shall be designed and constructed in a manner that prevents the accumulation of water within the wall assembly by providing a water-resistant barrier behind the exterior veneer as required by Section R703.2 and a means of draining to the exterior water that enters the assembly. Protection against condensation in the exterior wall assembly shall be provided in accordance with Section R601.3 of this code. Exceptions: 1. A weather-resistant exterior wall envelope shall not Commentary: As part of providing a weather-resistant exterior envelope,2.1. Exterior wall envelope test assemblies shall include exterior walls are required to provide water resistance. This section prescribes two basic components of providing water resistance for an exterior wall assembly: a water- resistive barrier installed between the covering and substrate of the exterior wall and a means of draining moisture that may penetrate behind the exterior wall assembly back to the exterior. Section R703.2 is referenced for the requirements of the water-resistive barrier (see commentary, Section R703.2). This section does not, however, contain a prescriptive requirement for the means of drainage. The method to provide the means of drainage is a performance criterion and must be evaluated based on the ability to allow moisture that may penetrate behind the exterior wall covering to effectively drain back to the exterior. This can be achieved in many ways including, but not limited to, providing a rain-screen pressure-equalized type of exterior assembly, or providing discontinuities or gaps between the surface of the substrate and the back side of the finish, such as through the use of noncorrodible furring or two layers of Grade D paper. For common types of construction, such as vinyl siding or brick veneer, the typical practice of installing building paper, flashing and weeps will comply with the intent of this section. For stucco or adhered masonry veneer, installing two layers of Grade D paper and flashing will comply with the intent of this section. Discontinuities between the exterior wall covering and substrate must be such that they encourage the flow of moisture via gravity or capillary action to a location where the water may exit, such as at flashings and weeps. The absence of a means of drainage may result in the accumulation of moisture that becomes trapped between the wall covering and the substrate. Over time, extended exposure to moisture may contribute to the degradation of the wall covering, building substrate or even the structural elements of the exterior wall. Exception 1 states that where the exterior wall envelope is designed and constructed of concrete or masonry materials in accordance with the requirements of Chapter 6 and flashed in accordance with Section R703.7 or R703.8, the water-resistive barrier and a means of drainage may be omitted. This is because the penetration of moisture behind the exterior wall covering is not detrimental to concrete and masonry substrates. Exception 2 permits the use of exterior wall coverings that do not have a means of draining water or meet the prescriptive requirements of Sections R703.2 and R703.8, provided that the exterior wall envelope, with penetration details, demonstrates wind-driven rain resistance when tested. The test specimen(s) must incorporate the penetration and termination details intended for use. Only details that have not allowed water to penetrate will be permitted to be used in the exterior wall envelope. The minimum panel size specified represents that which is commonly used in testing to ASTM E 331; however, this does not preclude the testing of larger panels if desired. The modifications to the test pressure differential and test duration are intended to represent more closely conditions that will be encountered in service. The pass/fail criterion is based on the visual observation of moisture on the interior side of the wall assembly. For frame-type wall assemblies, such as stud walls, this requires the observation of locations such as the interior face of the exterior wall sheathing and wall framing members for the presence of moisture during the test. The test method is intended to assess the performance of the method(s) and material(s) used to seal the interface between the termination of the exterior wall covering and the penetrating item(s) or abutting construction. The test is not necessarily intended to test the performance of the penetrating item. Walls designed and constructed in accordance with this chapter must also comply with the requirements of Chapter 11 of the code. This requires that frame-type wall assemblies be protected from moisture infiltration from the building interior through the use of a vapor retarder (see Commentary FigureR703.1) or by the ventilation of the wall cavity within a frame-type wall assembly." "R703.2 Water-resistive barrier. One layer of No. 15 asphalt felt, free from holes and breaks, complying with ASTM D 226 for Type 1 felt or other approved water-resistive barrier shall be applied over studs or sheathing of all exterior walls. Such felt or material shall be applied horizontally, with the upper layer lapped over the lower layer not less than 2 inches (51 mm). Where joints occur, felt shall be lapped not less than 6 inches (152 mm). The felt or other approved material shall be continuous to the top of walls and terminated at penetrations and building appendages in a manner to meet the requirements of the exterior wall envelope as described in Section R703.1. Exception: Omission of the water-resistive barrier is permitted in the following situations: 1. In detached accessory buildings.Commentary: Asphalt-saturated felt or any other approved water-resistive material is required behind all types of materials used as exterior wall coverings because of the possibility of moisture penetrating the substrate behind it. This felt or other material protects the wall construction from potential rotting. The water-resistive membrane may be omitted where there is a low possibility of moisture penetration or the potential for moisture penetration is not a great concern. The water-resistive membrane may be eliminated when approved paper backed stucco lath is used; the paper backing functions as the membrane if the backing paper is not punctured. The paper backing must be an approved water-resistive sheathing paper." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 6/16/11 at 12:45 AM.. |
I think I shall start reporting it. There is no solution, but the information could help a buyer make an informed decision. I would not want to buy a house without it..."what else did the builder scrimp on" would be going through my mind.
I've not even been looking for it, since just because you see it doesn't mean it's everywhere nor does it mean it's put on right. But I had a house today with water intrusion in the wall, probably due to a poor flashing job and the lack of house wrap. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I don't think it was in the IRC until 2006. Does anybody know?
Weather resistant barrier is the term more commonly used in building science. That term is inclusive for air leakage/exchange and other functions. |
I caught a brand new home with vinyl siding without house wrap, a few months back. The buyer had to argue with the local building inspector, before the building inspector agreed to make the home builder tear off the siding and install house wrap.
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
The one I did yesterday was 2 years old. I see the requirement in the IRC as far back as 2000 (that's the oldest book I have).
From the Vinyl Siding Institute.
The Vinyl Siding Institute (VSI) is the trade association for manufacturers of vinyl and other polymeric siding and suppliers to the industry. http://www.vinylsiding.org/installation/manual/ Water-Resistive Barrier Vinyl siding has always been designed as an exterior cladding, not a water-resistive barrier. Vinyl siding is designed to allow the material underneath it to breathe; therefore, it is not a watertight covering. Because of its design and application, it provides a supplemental rain screen that enhances the water-resistive barrier system by reducing the amount of water that reaches the underlying water-resistive barrier. What Is a Water-Resistive Barrier System? It is a system that includes water shedding materials and water diversion materials. Water-resistive barrier systems commonly consist of a combination of exterior cladding, flashed wall openings and penetrations, water-resistive barrier material, and sheathing. Effective water-resistive barrier systems will shed the water initially, control moisture flow by capillary and diffusion action, and minimize absorption into the wall structure. The level of water resistance required is determined by the applicable building code and structure. Best Practice: To achieve designed performance, vinyl siding must be installed over a water-resistive barrier system that includes 1) a continuous water-resistive material and 2) properly integrated flashing around all penetrations and where vinyl siding interfaces with other building products such as brick, stone, or stucco. Refer to the manufacturer’s instructions for specific product applications and recommendations. Whichever product(s) you decide to use as part of a water-resistive barrier system, be certain the materials meet the applicable building code by contacting the manufacturer of the waterresistive barrier material(s). Always consult the applicable building code for minimum water-resistive barrier requirements in your area. Keep in mind that additional measures may provide better protection against water intrusion than the minimum requirements of the building code. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
http://www.bsdsoftlink.com/library/history/072500.htm
- Air Barrier: Retards air passage, is water vapor permeable, and is liquid moisture resistant. Air barriers are assumed to be vapor permeable because they are commonly installed on the cold side of exterior walls where a vapor retarder might be inadvisable. If a vapor retarder is appropriate in such a location, don’t call it an air barrier, even though it does perform that function. Air barriers offered are mechanically fastened sheets ("housewraps") and spray or roller applied coatings. An air barrier can function as a water-resistive barrier (see below). - Vapor Retarder: Retards passage of both air and water vapor. Must be sealed at joints and penetrations. Vapor retarders are used on the "warm" side of walls to preclude condensation inside the wall or insulation. Vapor retarders offered are mechanically fastened sheets, self-adhesive sheets, mastic and spray coatings. - Water-resistive barrier: Neither air barrier nor vapor retarder but is liquid moisture resistant. Water-resistive barriers only protect the construction from damage due to precipitation. (The term "water-resistive barrier" is from the ICC International Building Code, 1404.2, which requires a minimum of one layer of No. 15 asphalt felt behind exterior wall veneer, unless other conditions are met.) Water-resistive barriers offered are No. 15 asphalt felt, waterproof Kraft building paper, and "housewrap" sheets installed lapped but not sealed. An air barrier can be used as a water-resistive barrier. Many other materials and components specified in other sections can make up part of the entire "weather barrier". This section does not contain any provisions that define the air or vapor performance of those other materials. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Been calling it out for years regardless of what the local AHJ says.
Doesn't make me many friends either except for the clients. Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
Particularly with Vinyl Siding Only method of repair is to strip and replace... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I always lift vinyl or aluminum siding at several locations to look for the presence of a weather barrier. When missing, I do include the purpose of weather barrier systems in the report, with a photograph of the bare sheathing. Have found many homes constructed in the 1990's and early 2000's without any barrier. Never had a client too concerned, yes the agents typically are not too happy! I recently had a water intrusion issue in my home constructed 1988. The "builder" neglected to cover the damaged wall with Tyvek, water seeped behind the siding and eventually destroyed the OSB and entered the wall cavity. A proper weather barrier with drainage would have prevented the damage.
| Coming soon. Free, online, fireplace and chimney inspection course. | gromicko | General Inspection Discussion | 15 | 12/14/09 4:19 PM |
| Electrical Inzpections | jtedesco1 | Electrical Inspections | 9 | 9/14/08 9:14 AM |
| **HOT** Texas Inspectors use of REI-7A-0 | escanlan | Legislation, Licensing & Legal Issues for Inspectors | 27 | 11/20/07 12:09 AM |
| WA State Legislative update | hmiller | Legislation, Licensing & Legal Issues for Inspectors | 153 | 5/4/07 11:55 PM |
| New Report Upload Technology | cdemsky | Miscellaneous Discussion for Inspectors | 49 | 5/1/07 10:19 AM |
