This is the first roof I've inspected that didn't look like it had any tar paper installed under the shingles. Roof was original to the home (16 years old).
What do you say when you find this? (Can't really tell from the picture but I pulled it up further and didn't see any. It could be farther up the roof, but not at the first row.) Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Common find in areas of the state with no building codes. House wrap is rarely used, as well. Of course, the clients are paying as if they had all required elements in their new roof....but this is called "profit" and later discoveries are written off as "It's not a defect if there is no code."
You mention that it is missing and the likelihood of leaking and/or damage caused by ice damning, broken/missing shingles, etc. and recommend that a roofing contractor (from an area that licenses them) evaluate the roof to determine if it requires replacement. Then you ask the real estate salesman for your card back since it is a sure bet that they will not be using it in the future. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
gmoore7 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am not sure about the States but in Canada eave protection is not required if the overhang is greater than 2'-11". Does not happen often but it is worth knowing if you are inspecting a high end home with massive overhangs.
i just seen that your roof is 20yr. this is more common with 20yr that the rest...
to add when you were in the attic could you see between the ply wood gaps to see if there was felt or see the back of the shingles? just a thought?
Didn't notice when it attic. Hind sight says I should have looked though, at least around the penetrations.
I say "Once the shingles have been applied the paper does not serve much purpose".
Tarpaper is a waterproofing material. The shingles simply shed water.
As a consumer, I would be wondering why I bothered to hire the first guy. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
If the roof has a leak, tar paper is not going to stop the water. especially when it has several hundred holes in it. It helps, but stops being a waterproofing when the shingles go on. I have torn off several roof with no tar paper. The builders cut corners here because its not required.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
So what do you say in an inspection report when you find it like this?
I would explain the advantages of having it, and recommend it be installed when the roof is replaced. I think the possiblity of a leak would overrule the other option, a compleate tear off. If the code required it, and the seller had the warranty and installer info, then you might be able to do somthing about it. In most situations that will be unlikely.
| Obama printing lots of gold... paper money will increase in value! | gromicko | General Inspection Discussion | 4 | 1/29/09 1:33 AM |
| As promised - Review of Newman's second radon study | Caoimhín P. Connell | Ancillary Inspection Services & Additional Topics | 2 | 1/26/07 8:05 PM |
| building paper | Rafael | Exterior Inspections | 4 | 4/4/06 7:29 PM |
