I just completed an inspection today. This house has a decent size deck in pretty decent condition at first glance. When I moved in and was checking it out from the underside I noticed just about each footer has major cracks in them. What do you think?
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. Last edited by jkeilson; 12/13/11 at 7:42 PM.. |
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
From photos it looks like they dug a hole, set the post in it, and poured concrete around it. Not the true description of "footer". Movement at post will cause concrete to crack.
edit: post, not "pole" Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
That was my first thought. unless someone has other trhories I'll buy that one. Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
The wood is getting wet and expanding which is causing it to crack at the corner which is where the greater stress is. I would also speculate that the concrete was from a bag and may not of been mixed correctly resulting in lower strength but thats just a guess.
Post should sit on top of the concrete with the proper connector.
Water is getting in and either expanding the wood or freezing in the winter. Here's a good link http://www.strongtie.com/products/connectors/EPB44T.asp Russell Inspection Services New Hampshire state license # 57 Level I Thermographer, ITC Certified Building Science Thermographer, ITC Certified Building Analyst, BPI Certified Commercial Inspector, ITA Certified Septic Evaluator, GSDI #148 www.newenglandthermalimaging.com www.russellinspectionservices.com www.nhsepticinspection.com Last edited by prussell; 12/13/11 at 7:35 PM.. |
I agree with the weak cement in conjunction with possible freezing action. Ice is strong and will break a lot of otherwise strong materials.
I agree with Peter!
I no way should the treated lumber be imbedded into the foundation. This only works for setting in fence posts. The other thing missing with this deck is post-to-girder diagonal bracing. This would have put extra stress on the corners. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Unreinforced concrete and improper embedment of the posts.
One heck of a large party the other night added weight to the footings.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
| Ontario Legislation - Anyone know what's happening? | Joe Ferrante | Canadian Inspectors | 6 | 9/30/11 6:15 AM |
| What is happening here? | evandeven | Electrical Inspections | 5 | 3/17/11 2:26 PM |
| What's happening here? | dvalley | Thermal Imaging, Infrared Cameras & Energy Audits | 56 | 3/5/08 8:09 PM |
