How many of you guys walk the roof during a roof inspection?
| Find an InterNACHI certified District Of Columbia Home Inspector (and anywhere else in North America) |
I get on all roofs if it’s safe….I know it’s not required per the sop; however you cannot see everything from the eaves with a ladder, my 2 cents.
Every roof that I can safely.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Never.
Yes.
If I can get to them. Most of the stuff I inspect are 3 and 4 story row homes. I find myself shoving a ladder out a window alot and setting up on an addition or porch roof to get up to the upper levels.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
every one, unless its not safe
Everyone that I can do safely.
I also walk all roofs that I can safely access. I also use every other viewpoints at the house (upper level windows overlooking lower roofs) as well. I avoid walking clay or concrete tile, and slate roofs whenever possible, but, look at them from the eaves.
Hope this helps. Jonathan Jonathan N. Leahy President A Rock Solid Home Inspection, LLC. www.arocksolidhome.com 303-718-7779 Residential Home Inspections, Radon Testing, Mold Inspections |
Depends on weather, height, access, condition and roof style.
Yesterdays inspection was wet and mossy areas. Not walking it. The other day was a tile roof. Not breaking it. Some houses have ravines and portions of the roof may not be visible. About 2 months ago I had an inspection on a lower slope ranch that had been previously inspected. The inspector missed the chimney as the crowns/flues were heavily damaged. He did not walk the roof and there was a creek in the back. I document pertaining to each inspection on method of roof inspection. I will not walk on brittle shingles as I will damage them. One time an inspection friend noticed me on a snow covered roof stopped and yelled at me. He was right. I was dumb that day and no longer walk on snow covered roofs. I have been fortunate the one time I feel I did not get hurt. Do not place your ladder on a deck surface. |
ditto, although I will not walk a significantly worn roof either. www.MauiHomeInspections.com |
Only when it is safe to do so.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Yes??? That sound like "all inclusive"--meaning you walk on all roofs. All the time.
Now what do you do if the roof is snow covered--or has ice on it. What about slate roofs, especially wet slate?? "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Brian is in AZ. No snow here. Not many slate roofs. Not much rain.
| Before You Start Repairing or Replacing Roof Finishes from CMHC | mkyriacou | Canadian Inspectors | 0 | 9/17/09 12:52 PM |
| Roof Decks and their problems | wdecker | Miscellaneous Discussion for Inspectors | 4 | 4/29/09 8:26 PM |
| reason to walk the roof | psiposs | Exterior Inspections | 64 | 5/13/07 11:55 PM |
