I know I should know what the proper technical term is for this face plate beneath the front entrance door is, however, I don't and can't find it anywhere in my resource library. Anybody want to take a stab?
Shore-Footed Property Services, LLC Stephen P. Shockley MD Licensed Home Inspector 410-726-3471 Salisbury, Md |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Threshold.
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
Dah!...I should know this. Thanks gentlemen.
When big enough to sit on does it become a stoop?
Hey Stephen, I call it the sill support (or threshold support). The threshold is attached to the sill and is supported by the piece of wood in your picture.
Good point Robert. Thanks.
Either way works for the report.
I try and keep it understandable for the client so as long as they understand when reading you are fine. Recommend sealing exterior threshold works fine for me however seal sill support does the trick also if you have a pic in the report. |
Trying to get them in there. The new HIP Android version (not out yet) is rumored to feature search as you type, meaning I may change over from my narrative approach. |
Re-cladding the threshold.
Suspect: Bent, dinted, folding cladding with degrading paint at the door frame and trim on the exterior moldings and the threshold. Recommend: Paint all open exposed wooden areas, Refasten separated wooden casement framing and trim using finishing nails to size. Caulk all exterior trim work around the door framing and threshold. The cladding looks bent.
montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Door sill is damaged, repair is recommended.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
It was bent up a little on the edge. Wasn't the best I've seen at customizing wood trim on a house.
| Agent kick backs | jdeese | Florida Inspectors | 27 | 9/28/11 4:24 PM |
| Crawlspace moisture damage repairs - sill plate | jfrederick | Structural Inspections | 3 | 1/8/11 5:07 AM |
| Shot-In Sill plate anchors | lfoster | Structural Inspections | 7 | 11/10/09 7:54 PM |
| Sill plate overhanging stem | dbucknavich | Structural Inspections | 9 | 3/2/08 11:37 PM |
