Are dormers typically ventilated on a Cape Cod style? The dormer soffits had vents, however there was no ridge vent on the dormer peak. Modular house built in 2004.
Thanks. |
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Look at the total attic vent.
It has to do with ? sf per?sf of floor space. I'll let you look that one up. Where they are located has to do with elevation. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
The total net free ventilating area should not be less than 1 to 150 of the area of the space ventilated except that the total area is permitted to be reduced to 1 to 300 provided mechanical ventilators are used.
Was the decking cut to allow the air from the dormer to the main roof ? I've seen some that were not and they would need separate ventilation.
More pics.
Look it up!
Your area may be different. You may not even need ventilation.... Yes, I am not joking! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I don't believe I've ever seen a dormer that wasn't connected to the main attic. How did they install the windows if it wasn't connected?
If the floor space below the roof is heated then it should be vented in some fashion; the way we frame our dormers it is naturally vented.......simply because you do not see ridge or gable venting does not mean its not vented. If you were able to access the attic then you would be able to tell how it was vented.
Jeff |
Some modular home companies will install dormers separate and then apply siding after the fact. As I was driving home a couple weeks ago I saw one of the local modular home companies do just that.......what always blows me away is that they brag about how fast modulars go up.....yet many of them take just as long to finish out. It takes me about 12 - 16 weeks to build a custom home up to 2500 sq ft...... and I can do it less than what a modular cost in the end with more quality and value...... its amazing that they sell......but then again, hardly anything is selling around here.
Renki Kyne is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nice sharing,
Its really very good informative post about dormers ventilation. I am a newbie for this forum site, and I hope that i will get so useful information here. Thanks for sharing this. |
Kind of like the illustration, only imagine the rafters and sheathing cut out hand headed off, flush with the inside of the ledger. Structural ridge supported by posting down to window header at the outside wall so no rafter ties (ceiling joists). If the dormers had flat ceilings, they were probably vented into the attic. If the ceilings were vaulted, they had intakes but no exhaust and faulty ventilation. [IMG]file:///Users/kentonshepard/Library/Caches/TemporaryItems/moz-screenshot-4.png[/IMG][IMG]file:///Users/kentonshepard/Library/Caches/TemporaryItems/moz-screenshot-5.png[/IMG] Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Way More Intake To Supplement Minimal Exhaust Ventilation? | Ed Fako | Exterior Inspections | 1 | 12/19/08 6:07 PM |
| Almost vented directly out? | djones6 | Inspecting HVAC Systems | 15 | 4/12/07 10:38 AM |
