Okay this is a two year old composite shingle roof over a 21 year old asphalt composite shingle roof. My question is? None of the plumbing vents, skylights, or either chimney has visible flashing or sealant on the second layer. Is this practice acceptable? Was the thought process that the first layer was sealed so this layer doesn't need to be? Somebody help please?
| Find an InterNACHI certified Texas Home Inspector (and anywhere else in North America) |
The top layer of shingles requires flashing/sealing.
I just don't know how this was something overlooked on every single roof penetration. Would I find this in the IRC?
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
They did not follow the manufacturers installation instructions. |
This is one of the reasons double layering shingles is frowned upon. It is now harder to flash boots like these, and any flashing mistakes made on the first roof still exist. The rubber (neoprene) continue to degrade, and leave a weak point.
This is a mobile home? |
Anyway...the IRC says that penetrations will be properly flashed. These are not. Write it up. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
Simple question James just wanted to know what the actual code was. I am property inspector and I don't do codes. Thanks though. Yes Michael it is a mobile home.
Flashings shall be reconstructed in accordance with approved manufacturer's installation instructions. Hope that helps. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Also...
"R903.2- Flashing shall be installed in a manner that prevents moisture from entering the wall and roof through joints... ... and other roof penetrations." It has to prevent moisture intrusion and these are installed incorrectly. But I agree with Jim and Harry, I wouldn't cite the code, just say it's wrong, it may leak and recommend correction by a qualified contractor. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
If I don't observe exposed flashing on sloped roof penetrations (I don't care how many layers of shingles are installed), I call them out.
Disregard improper flashing at stack.
| Double lugged breakers? | dbook | Electrical Inspections | 7 | 4/30/08 12:35 AM |
| Asphalt shingles over wood shingles | kmalone | Exterior Inspections | 9 | 4/9/08 9:10 PM |
| 3 tab shingles curling | ccbrands1 | Exterior Inspections | 8 | 1/29/07 5:25 PM |
