Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 5/22/09, 9:31 AM
Rick Vollmer Rick Vollmer is offline
Please Note: Rick Vollmer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Drainage question
I have just added dirt to create a good slop around my fron and side block foundation wall, to aid in drainage. Now I have a question rearding the use of gravel. I have been told to put down weed control paper and then add the grave. But won't this allow moisture to come in thru the paper and be trapped? I have also been told to just use the gravel. I have bought 5 tons of number 57 gravel.
Some one else said to put down a layer of gravel, then the paper and then more gravel. To add more confusion I have heard to put down 6 mil plastic or roof felt, then the gravel.
I am a "little" confused to say the least, so I thought I would check with the pro's......
PS, I am not interested in growning any grass, flowers, tree's etc. around these areas.
Many thanks in advance....
Find an InterNACHI certified Kentucky Home Inspector (and anywhere else in North America)
Old 5/25/09, 12:59 AM
Mark Nicholet's Avatar
Mark Nicholet Mark Nicholet is offline
Default Re: Drainage question
Landscape fabric and gravel provides low maintenance landscape.
Grading slopes should be 1 inch slope away from the building for every 48 inches of non-permeable surface. 1 inch slope away from the building for every 12 inches of permeable surface.
Swales help direct water around the building.
French drains should be atleast 15' away from the building.
If hydrostatic pressure is an issue against the foundation then drainage board and damp proofing can help direct water to the drain tile, if any.
Hope this helps.
Mark Nicholet
Apple Home Inspections LTD
My Blog
CAHPI(BC) Associate member
InterNACHI member
Infrared-Certified
BC Licence # 47592
Old 5/25/09, 7:24 AM
David P. Valley's Avatar
If you have a basement and your attempting to improve grading around your foundation, you do not want to add gravel to this exterior foundation area. This gravel placement will allow water to seep faster (through the gravel) and seep down towards the footing drainage (if equipped) and eventually this water will work it's way into your basement.
A slab on grade is a whole different situation.
Old 5/29/09, 7:36 PM
Jerry Bettencourt Jerry Bettencourt is offline
If it is a basement as said above you do not want to add gravel you want to add soil to create the slope as gravel will allow the water to drain down not run away from the foundation.
JERRY BETTENCOURT
HOMETEST HOME INSPECTIONS
www.hometestinspections.com
www.hamiltonthermalimaging.com
hometestinspections@hotmail.com
I will keep my thoughts positive because my thoughts become my words. I will keep my words positive because my words become my actions. I will keep my actions positive because my actions become my values. I will keep my values positive because my values become my DESTINY!
United Family Martial Arts Student Creed
Old 5/30/09, 6:12 AM
Jerry,
Can you read?
Old 5/31/09, 11:01 PM
Originally Posted by dvalley View Post
Jerry,
Can you read?
Usually, I misread that one I need to get my money back from that speed reading class!
JERRY BETTENCOURT
Sump Pit/Pump Question Joey D'Adamo Plumbing 4 11/26/08 2:04 PM
What's this video worth? jtedesco1 Education 5 4/18/08 10:24 AM
gutter downspout to basement drainage system David Paterson Exterior 2 12/18/06 7:27 PM
Copyright © International Association of Certified Home Inspectors, Inc. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
