Old 6/20/09, 1:33 AM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Default Drip Edge
I am trying to remember if the drip edge should be behind the gutter or not? This one was not.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America)
Old 6/20/09, 3:15 AM
Tim Spargo's Avatar
Default Re: Drip Edge
I have a "brain fart" once in awhile too....
Drip edge would have been put on at time of roof installation, gutter after. Was trying to see if that was starter course on shingles or not... just curious.. we all have diff ways we do things, I will try to pull up the shingles a bit when I ladder up to the roof and look for layers, felt and metal config.
Take care.
Tim
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 6/20/09, 10:23 AM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is online now
Preferably behind, not always possible. My installer cut slots in my drip edge to get it high enough in the middle to drain to the sides.
Old 6/20/09, 11:08 AM
David P. Valley's Avatar
With the gutter butting up tight against the underside of those shingles, I wouldn't call out a missing drip edge. That installation is fine.
Then again, the drip edge flashing wouldn't even be that hard to install with the gutter in place.
Now if the gutter was installed a tad lower on the fascia board (leaving a fascia gap) then a drip edge would be considered missing.
Old 6/20/09, 11:19 AM
Darren Spencer Darren Spencer is offline
All the roofing associations highly recommend the use of drip edge. You can find that info in the installation directions. I always make note of this in new builds. If we just make buyers aware then maybe one day the builders will start having better practice.
Need a Link Exchange? Inspector Links
Seattle,WA Commercial Inspectors
Old 6/22/09, 8:41 PM
William J. Decker's Avatar
Just had my roof replaced, by a company where I know the owners.
I had to re-write the proposal specs:
Ice & Water Shield (I&WS) on both the eaves and rakes.
Drip edges on both.
I&WS over the drip edge on the eaves and under it at the rakes.
6' of I&WS at the eaves, instead of the usual 3' (Chicago, home of the ice dam )
Chimney counter flashing cut into the mortar joints, rather than just caulked.
he thought I was crazy, but added $350 to the quote. I told him that these were the current "best practices". He told me that he didn't know that (even though he is a member of the CHicago Roofing Council).
Also, he is a good guy. He never uses nail guns to shingle a roof, only hand nailed.
But, he told me that it was getting very difficult to get work, doing a "best practices" job when there are so many other "shingle nailers" (NOT state licensed roofers, which is required in Illinois) underbidding him.
So, it's not just HIs that are getting low balled by non-professional competitors.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 6/22/09, 8:46 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Why I & WS all the way up the rake edge?
And why the problem with a nail gun?
Old 6/22/09, 8:48 PM
rmaday's Avatar
Ditto
Drip edges on both.
I&WS over the I&WS on the eaves and under it at the rakes.
I think you mean drip edge where bolded and underlined, no?...otherwise I don't get it.
Larry Kage, CMI
231 929 3525
Old 6/22/09, 8:58 PM
Over the drip edge. Sorry. I will correct.
Will Decker, CMI
Old 6/22/09, 9:02 PM
1) to guard against water intrusion at the rake. Very common with our high winds and ice.
2) Nail guns are, rarely, properly adjusted and can dimple the chingle too much, or eve tear it. There should always me a little play under the nail head.
BTW: Good thing my daughers are fluent in Spanish. The actual installers didn't read the specs. I could have let them go on, and then called my fiend out to redo the work (as not complient with the contract, but we (my daughers and I) took it as a "teaching moment".
Will Decker, CMI
Old 6/22/09, 11:20 PM
Nail guns are, rarely, properly adjusted and can dimple the shingle too much, or eve tear it.
I found one roof 3/12 pitch, 3 tab shingles, 10 years old, where the air pressure/nail gun was not adjusted properly, and the nails were held up, and allot were not sealed at all. You can get into trouble faster with one, however if you know what you are doing, you can haul butt, and still do it right. There is allot in the right gun, but way more adjustment in the user.
I have also heard from roofers that they are starting tear off whole sheets of sheeting, rather than attempt to tear off Ice/water shield. Plan on it when that time comes around again.
I do know contractors that will Ice/water shield the WHOLE roof, and wait to shingle it till they feel like it, (up to 3 months) wonder how much sheeting they will be tearing up in 20 years?
Old 6/23/09, 12:08 AM
Chuck Evans's Avatar
Here's what you can get with a maladjusted air gun. This was a brand new roof. All the nails driven completely through the shingles. The shingles were just being held by gravity and were sloughing off in some places. I'm sure that if the sellers didn't get the roof redone, IKE must have stripped it bare.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 6/23/09, 12:19 AM
rmaday's Avatar
You can also find guys (hand nailing) swinging a hammer for the first time or skipping nails, or...
Well, you get the picture
Originally Posted by mroberson View Post
Iif you know what you are doing, you can haul butt, and still do it right. There is allot in the right gun, but way more adjustment in the user.
And that is exactly my point. It matters not what tool is being used (hand or nail gun), it matters who's using the tool.
Old 6/23/09, 12:21 AM
rmaday's Avatar
Not the guns fault.
Guns don't kill roofs, people kill roofs.
Roof drip edge sfalvey Exterior Inspections 11 10/6/08 10:37 AM
Asphalt shingle overhang at drip edge jcampbell Exterior Inspections 8 11/10/06 8:48 PM
Lack of aluminum drip edge Brenda Exterior Inspections 26 6/16/06 8:28 AM
