Old 6/23/09, 2:11 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Drip edges
Would anyone say anything about these drip edges being bent at the edge and the valley missing the gutter?
Thanks!!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America)
Old 6/25/09, 6:25 AM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Drip edges
Valley may be an issue. But, with gutter screen there, it will always overflow in moderate to heavy rain.
Old 6/25/09, 6:28 AM
David P. Valley's Avatar
The gutter installer damaged the drip edge to install the gutters and this should be noted.
Old 6/25/09, 6:47 AM
I suppose the gutter installer would argue that although he "altered" the drip edge from its original state, in doing so he actually is preventing a future problem.
1. If he were to cut the drip edge moisture would follow the bottom track of the drip edge and get between the rake board (which isn't caulked) and gutter thereby deteriorating same over time; yes that joist could be caulked but caulking does not
last the 50 years as advertised, well not at holding its adhesion.
2. even though the drip edge is bent, it does function as intended.....moisture is not going wick back underneath the shingles or sheathing.
Personally I would have cut it slightly larger, forming an inside corner between the gutter and rake board so that I would not have to caulk.....but that's from knowing secrets of the trade....... and willing to take a few extra minutes to do it right.
I would note it in the body of the report as a cosmetic issue since I believe it still functions as intended.....albeit unsightly.
The valley missing the gutter is a design issue.....but more troubling is the gap between the metal valley and drip edge.......you are going to have a problem there......that is your biggest concern. A roofing contractor needs to address that area.
regards
Jeff
Old 6/25/09, 6:52 AM
If the installer simply measured the fascia area correctly (gutter overhang), this bend would have never happened.
Old 6/25/09, 8:36 AM
Thanks!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Propane drip leg mboyett Plumbing Inspections 1 1/11/09 9:23 AM
Drip legs Scott Schultz Plumbing Inspections 7 3/31/07 7:46 AM
Condensate in the Drip Pan Skip Erwin Inspecting HVAC Systems 4 7/20/06 11:45 AM
Lack of aluminum drip edge Brenda Exterior Inspections 26 6/16/06 7:28 AM
