Todays inspection was exhausting. My shutter finger is sore from taking so many pictures. Anyway...I was doing a termite inspection in addition to the home inspection on the property. The house was clad in aluminum siding, so I was checking to see if there was any damage to the sheathing underneith. I ran my fingers under the bottom edge to see if I could pull out any frass or some cobwebs with frass or dead insects and I felt something really strange. I took out my inspection mirror and tried to see what I was feeling. I was feeling wet paper and was getting white particles dropping on the face of my mirror. Someone sheathed the entire exterior of the house with drywall and covered it with aluminum siding. The siding job was horrible too. What was going through this idiot's head when he did this?
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Hey Scott... sheetrock is cheap, really cheap....
Doesn't look like he splurged on green board either...... Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Back in the day there was a gypsum product that was made for exterior underlayment. Black paper faced 2x panels that installed horizontally, the paper may have been asphalted. The top edge was convex and bottom edge concaved so they interlocked. We just call it gyprock. I think it was USG product if my memory serves. I still find it on old EIFS and stucco jobs. I try and find a pic.
BTW: The cut end was never meant to be exposed, DUH! Once wet it turns to mush. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
In Canada, exterior grade drywall has been allowed by codes for years as exterior sheathing. There are whole subdivisions built in the 1960-70's with the stuff.....houses are still standing!!
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nice catch Scott, did you recommend blue board?
I see it was raining in your area as well .... flood warnings still being broadcast up here. |
They use drywall for sheathing all the time around here. Commercial work, in particular. They yellow faced drywall is manufactured specifically for this application.
I've never dealt with the stuff, but here's some info I found searching for gyp sheathing.
http://www.gypsum.org/pdf/GA-254-07.pdf |
I would have never guessed that a paper coated product could be used outside. Regardless of what the manufacturer say in their literature, I would never have a paper coated product under my aluminum siding. Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Common in Philadelphia area as the Gypsum manufacturing plant was located on the river in South Philadelphia ... http://www.workshopoftheworld.com/so...us_gypsum.html Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
grusk is a non-member guest and is in no way affiliated with InterNACHI or its members.
For years some county and cities have require fire rated drywall on the exterior of homes being built, if the houses are within so many feet of each other. At least on the exterior adjacent to other houses or buildings next to or behind the home being built. Years ago I framed some homes in Md., Washington D.C. and Va. that we had to put fire rated drywall on.
Gary |
Exterior gyp rock! Not uncommon in the kc metro for a period of years either.
Dens-glass ie: the yellow colored is still use under EIFS most of the time on commercial buildings. "I create controversy whether they like it or not" |
It looks like this; Attachment 19364 Attachment 19365 Attachment 19366 Here, it is behind siding and behind brick above. Good product. Also used quite a bit behind DryVit, and Sto systems commercially. EIFS Hope this helps. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 Last edited by mcyr; 9/6/08 at 7:50 AM.. |
Here is the Application of Gypsum Sheathing document that goes with what you found. LINK to American Gypsums prouct line. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Popcorn Ceiling | prubenstein | General Inspection Discussion | 10 | 2/7/08 10:12 PM |
| Use of ThermoPly without underlying structural sheathing? | koconnor | Structural Inspections | 12 | 10/16/07 7:52 PM |
| Exterior sheathing | adooley | Exterior Inspections | 8 | 2/16/07 9:42 PM |
| Drywall finishing | dmacy | Miscellaneous Discussion for Inspectors | 17 | 1/25/07 1:29 PM |
