I'm looking for a few high resolution dry well illustrations and images.
I'm working on a web page for a dry well installation and I desperately need high resolution images to assist in my explanations. Can someone help me out? |
David...I Googled "dry well" and several decent drawings came up. They may be copyrighted but if they suit your needs then maybe you could ask for permission to use them.
Example:
Not quite sure what you are looking for, but here goes.
![]() ![]() ![]() ![]() Large Drainage Rings ![]() ![]() All concrete has a minimum of 4,000 PSI compressive strength at 28 days. Each 4' high ring has a capacity of 933 gallons plus the capacity of the crushed stone backfill. These rings can be made shorter, or if need be, stacked for larger capacity. ![]() ![]() Hope this helps David, if not let me know. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
| Main shut off illustrations needed. | dmacy | General Inspection Discussion | 12 | 8/28/07 1:11 PM |
