Old 2/1/08, 1:59 AM
thance thance is offline
Please Note: thance is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default EIFS Assistance Please
My first EIFS (DRYVIT) home....shouldn't trims have a DRYVIT compatible sealant and closed cell backer rod? At least that's what I've been reading.... And, if so, would such an installation be evident from the exterior? The trim appears to be EIFS as well. Thanks very much.
Old 2/1/08, 2:06 AM
cgoyette cgoyette is offline
Please Note: cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: EIFS Assistance Please
Do you have some better photo's?
Curt
Old 2/1/08, 2:26 AM
Here's a photo of a typical window.
Old 2/1/08, 5:15 AM
Barry Adair's Avatar
Tim,
In a perfect world the trim on EIFS and a lot of stucco is glued on with the PB-PM material and maybe mechanically fastened onto the preexisting wall, basically an ornament.
As long as all the penetrations are properly flashed and backer rod sealant joints are present at the dissimilar contact points (EIFS to any other type of materials) all should be well.
For the best performance with EIFS systems many manufactures recommend that a low modulus sealant such as Dow 790 for EIFS to EIFS joints and Dow 795 as a perimeter seal around all windows, doors and other through wall penetrations and other dissimilar materials abutments. Alternative low modulus sealants shall have been tested in accordance with ASTM 1382, Test Method for Determining Tensile Adhesion Properties of Sealants When Used in (EIFS) Joints.
If you have not been specifically trained and have the testing equipment to fully evaluate EIFS I would recommend you refer these to a specialist whether you see problems or not.
This or similar is what I've sent to almost every inspector within a hundred miles of me, feel free to change it to suit your inspector and region:
Suggested EIFS/Stucco boilerplate for your reports:
The subject property is clad with an Exterior Insulation and Finishing System (EIFS) also referred to as “artificial or synthetic stucco”
A Certified EIFS/Stucco Inspection is beyond the scope of this inspection.
Many EIFS/Stucco clad homes have had moisture intrusion related problems that can only be identified by a Certified EIFS Inspection.
This along with proper maintenance recommendations is imperative to identify, minimize, and or prevent these problems and avoid costly repairs.
“I/We advise having this specialized inspection performed prior to closing.”
Contact: Barry Adair at (214) 328-8331 for EIFS/Stucco Inspection appointment scheduling and further information http://www.adairinspection.com/EIFSInspection or the vendor of your choice http://www.awci.org/contractors/inde...xperience=EIFS
Team up with someone in your area that really knows EIFS, good luck.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 2/1/08, 8:25 AM
Barry is right, as usual. If the home was done correctly (post 1998 usually better, but not always) your moisture readings should reflect it.
What was the Moisture readings around the penetrations?
I assume you mapped the home and used a Tramex Moisture meter.
Curt
Old 2/1/08, 9:16 PM
Thank you Curt, Brian, & Barry! I really appreciate your input and sage advice.
I told the client that I was not a certified EIFS inspector, that I would be recommending one as a matter of course, and gave him the standard EIFS disclosures, information, and limits of liability before even contracting to inspect the home. After these disclosures and information, he "just wanted someone to put an eye on it." So, I did and made additional recommendations for suspect/vulnerable areas. No elevated moisture readings were apparent.
And, thanks Barry for language suggestions; I used portions in my Report.
Old 2/2/08, 1:39 AM
I hope you used all of it I could really use a paid vacation, when should I expect their call?
Have Tools, Will Travel
ADAIR INSPECTION
972-487-5634
TREC # 4563
Need bad EIFS photos sspradling Exterior Inspections 18 12/2/07 6:06 PM
EIFS question tjansson Exterior Inspections 3 5/14/07 6:07 PM
