Old 4/19/07, 3:57 PM
Default EIFS bulge/cracks at top plate transition
This bulge/crack right where the rim joist meets the wall top plate was typical all around the building to various degrees. No penetrations were caulked, but no obvious avenues for moisture above these areas either.
What besides moisture behind the EIFS would cause this?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 4/19/07, 10:54 PM
Carl A. Brown's Avatar
Default Re: EIFS bulge/cracks at top plate transition
When the wood that is not cured right dries out and shrinks. Life in the fast lanes. Nothing is done right from the ruffin to the finish. Quick growth wood!
And it happens with all sidings not just EIFS!
Old 4/20/07, 12:02 AM
Joseph Hagarty,  CMI's Avatar
Agreed
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 4/20/07, 12:28 AM
Same as what Carl said plus no floor line control / expansion joint. From your perspective: Various improper conditions noted in the EIFS, such as: .........., we recommend having a EDI or AWCI certified stucco inspector do further evaluation and moisture testing of the EIFS system prior to closing.
Old 4/20/07, 1:31 AM
Dale Duffy's Avatar
Ditto Ditto Ditto....Carl, Joe, Dan..!!!
Old 4/21/07, 11:56 AM
gbrasseur's Avatar
gbrasseur gbrasseur is offline
Please Note: gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree as well. Contractors purchase Green lumber often instead of KD or S-dry, because they save 0.20 per 2x4! They just can not seem to see the future problems like this ......but they sure did save a few hundred bucks on the lumber sigh
Old 4/25/07, 11:03 PM
David A. Andersen's Avatar
In your picture I see a window and an electrical fixture. They look like "obvious avenues for moisture" to me. Isn't that what your asking?
With out moisture testing, this just looks like bad workmanship.
Old 4/26/07, 12:43 AM
Well that's true, David. The cracking was so consistant around the building and it seemed to me that single points of entry on different sides would show up differently and that the damage would look more related. Some areas had similar damage but no point similar point of entry.
Here's a couple good ones of the same building:
1. the roof/wall junction
2. its termination in a hole at the bottom
It was pretty much like the hole at a miniature golf green. The amazing thing was that looking at the stucco below the gutter, there was only very slight visual evidence that anything was wrong.
(303) 717-8940
Old 4/26/07, 6:30 PM
Around here, real estate agents avoid stucco homes like the plague!
They probably have a point there!
From what you are showing us, there seems to be some serious potential problems here. I think further intrusive inspection is in order.
Old 4/26/07, 9:32 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Makes me think how with all the EIFS being installed for energy conservation on new and existing dwellings,getting certification to inspect this stuff may be a better add on service than mold inspection.
Old 4/27/07, 1:52 AM
Barry Adair's Avatar
Works for me!
Check out http://www.exterior-design-inst.com/
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 4/27/07, 11:06 AM
relliott's Avatar
Thanks Barry.. I have had that link for a while.
I take it you found this to be a worthwhile pursuit.
EIFS question tjansson Exterior Inspections 3 5/14/07 6:07 PM
Skylights at slope transition mthomas2 Exterior Inspections 8 3/12/07 6:08 AM
