1999 condo conversion. 30' x 100' eifs wall with no control joints. Not buckling yet, but lack of control joints is a red flag, isn't it?
Also. some local cracking and damage. No visual evidence of interior water damage... yet. How concerned should I be about the EIFS defects? |
Very concerned! How many penitrations are in the wall you are talking about?
"I create controversy whether they like it or not" |
Hi Thomas,
I would concider the lack of control joints a major defect, and would be very suspisious of any cracking in the finish, any damaged areas should be quickly repaired. The problem with this system is that I have never yet seen one installed in accordance with the manufacturers installation guidelines, and that any moisture getting behind the finish will destroy the sheathing long before its presence is visible inside the structure. I would recomend futher evaluation by a specialist in this type of finish. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Gerry ,
kinda hard on the plaster'ers aren't we! The sheathing most likley was not installed properly either! What was the sheathing? "I create controversy whether they like it or not" |
| Interesting Question? | jmckenna1 | Miscellaneous Discussion for Inspectors | 9 | 11/25/07 1:13 PM |
| Rule of Thumb A/C sizing question from Practice Exam | gliebig | Inspecting HVAC Systems | 9 | 5/25/06 1:38 AM |
| Answer to a common question about GFCI's | jtedesco1 | Electrical Inspections | 4 | 1/12/06 9:29 PM |
