Old 4/14/10, 12:47 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default EPDM?
Can you please confirm this is EPDM? No UV protection? Thanks.
ID:	36448   epdm-pict0373-small-.jpg.JPG
ID:	36449   epdm-pict0374-small-.jpg.JPG
ID:	36450   epdm-pict0369-small-.jpg.JPG
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/14/10, 12:49 PM
mnicholet's Avatar
Default Re: EPDM?
Vent stack flashing....
Old 4/14/10, 12:54 PM
mnicholet's Avatar
Default Re: EPDM?
Another view, it is my understanding that EPDM is typically a large membrane lacking seams.
Old 4/14/10, 3:15 PM
Nick Gromicko's Avatar
Default Re: EPDM?
Kenton wrote this: http://www.nachi.org/epdm.htm He would know. PeaktoPrairie@msn.com
Find a Home Inspector
Old 4/14/10, 4:39 PM
Default Re: EPDM?
Mark, that looks like EPDM, which has good UV resistance, but it looks poorly installed. It should be stretched tight over the roof. EPDM typically shrinks after installation. The seams are sloppy too.
EPDM comes in different sizes including rolls 10 wide, which is what that looks like. It's available in larger sizes. That roof could have been done without seams, but is looks like a homeowner went to Home Depot and charged right into the job. It should be glued down. I don't see any fasteners and it's obviously not ballasted.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 4/14/10, 5:05 PM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
Default Re: EPDM?
Looks like a Poorly installed Torch applied Modified Bitumen . The wrinkles are usually a result of the cap sheet installed beneth the roofing,or they went over a wrinkled hot mopped roof.
Old 4/14/10, 5:28 PM
Bob Elliott's Avatar
Default Re: EPDM?
It can be glued or heated.
Modified bitumen would be hard and thinner,feeling more like shingle material, while EPDM is a little spongy and thicker.
As Kenton stated it is already UV resistant.
Old 4/14/10, 5:39 PM
Default Re: EPDM?
Seeing the flow on the seems is a give away to me that it is Modified Bitumen .Could be wrong but in a previos life I was in the Roofing buisiness and we installed thousands of squares of the stuff up by you Bob. Easiest way to tell is EPDM is like an innertube, Glued,ballasted or fastened with batten strips usually in 10' wide rolls,Modified is typically 1 meter wide mopped or torched down
Default Re: EPDM?
The EPDM should be stretchier. You photos looked like the material might have had a network of cracks, which I would not expect to see in EPDM but might in mod bit.
EPDM is basically vulcanized rubber and mod bit is basically asphalt that has been chemically altered to be more durable and flexible.
(303) 717-8940
Old 4/14/10, 7:58 PM
Michael A. Gillingham Michael A. Gillingham is offline
Default Re: EPDM?
Looks like modified bitumen to me too. I've ran plenty of jobs with EPDM to be installed on the roof and that just does not look like it.
Old 4/14/10, 10:43 PM
measter measter is offline
Please Note: measter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: EPDM?
Put your Tramex or other conductivity non-destructive moisture meter on it. (make sure it's dry underneath)
EPDM is a conductive rubber (one of the few, but there are others). It will show a positive moisture reading everywhere. Mod bit will not.
V/R
Mark
Old 4/14/10, 11:43 PM
Default Re: EPDM?
V/R
Mark
Hope nobody Needs to go That far
Old 4/15/10, 6:28 AM
Default Re: EPDM?
I agree, all we have around here is EPDM and looks no where close to those photos.
This is an EPDM roof here;
And here;
Inspecting EPDM. Please proof this new inspection article. gromicko Commercial Inspections 3 3/31/10 11:44 PM
How to inspect EPDM roofing. inxil InterNACHI & RealMatcher Blogs 3 3/29/10 11:05 PM
Inspecting EPDM. Please proof this new inspection article. gromicko Exterior Inspections 0 3/29/10 5:56 PM
EPDM membranes bknowlton Commercial Inspections 5 3/25/10 9:27 PM
EPDM Question mkiss1 Commercial Inspections 2 6/11/09 10:41 AM
