Old 2/8/11, 12:09 PM
Tim Spargo's Avatar
Default Every time I find this defect I hear "I had the home inspected, no one said a word"
Doors get added into the sides garages all the time, many times the areas where the plate was cut lacks the addition of bolts/hardware or the framing was not designed properly for the addition of the door... an easy place to notice amateur like work? Doors with out exterior light fixtures.... they are required here (and most places) at grade level exterior doors
Of the many older homes I inspect, if there is a seller present, I will usually get a comment or feedback that they had the home inspected and no one said a word.
Tim Spargo
Spec Rite Inspections
661-317-5770
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/8/11, 1:35 PM
Jamie R. Wilks's Avatar
Jamie R. Wilks Jamie R. Wilks is offline
Default Re: Every time I find this defect I hear "I had the home inspected, no one said a wor
Tim
looking at the photo provided, I can understand listing the missing exterior light fixture.
the comment regarding "the framing was not designed properly for the addition of the door", is something I can not see. if the work was completed and then covered up or closed in, I'm not sure how an inspector could comment on the framing, etc.
Jamie R Wilks
North Star Home Inspections
VCHI #3380000351
InterNACHI #05081596
Old 2/8/11, 1:44 PM
Tim Spargo's Avatar
What I'm saying is... noticing a missing light fixture, is likely good reason to look for related defects
Tim Spargo
661-317-5770
Old 2/8/11, 9:06 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is online now
You can plainly see the recessed framing and the EFIS has been damaged slightly during the fitting..
The framing ( wood diameter ) is to small and insufficient. 2/8 2/10 with a header.
I see not header cut.
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Old 2/8/11, 9:24 PM
Bob Elliott's Avatar
It does look a little recessed.
Old 2/8/11, 9:30 PM
Doug Edwards's Avatar
Serious doubts too that the EIFS was correctly retrofitted around the new door and frame. At the top you can see the jagged edges of the EIFS finish. No back wrapping or transition joint and sealant around the brick molding. Hope you called it out as well as any place else like around windows, other exterior features that require it. It is extremely rare that I find any EIFS system that was installed according to the manufacturer's instructions, pretty much making it a nightmare waiting to happen. We have whole neighborhoods where it is installed wrong. Unfortunately no one wants to pay for an EIFS inspection until well after the serious damage has occurred. If it is as I suspect, no light is the least of their worries. In fact the lack of a light fixture may be a blessing in this case. One less place for moisture intrusion behind the EIFS.
- John Stuart Mill
Old 2/8/11, 10:42 PM
Another good point.
The EFIS should have been sealed and insulate the void with minamul expansive foam and the header would carry the electrical housing ( boxed insulated for wiring and meret ) . and light would be affixed to the top header plate.
Old 2/9/11, 1:19 AM
clambert2 clambert2 is offline
Please Note: clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Guys how do you know it is EIFS? Very few places in Calif have EIFS. That is a pretty big assumption.
Regular hard coat stucco
Chuck
Old 2/9/11, 3:28 AM
Stephen W. Stanczyk's Avatar
Yep. Looks like hundreds of doors installed in hard coat stucco in SoCal. Not sure when the exterior light was required around exterior garage doors. Homes from the 50's and 60's don't have them. They do around the home doors but not the rear garage door usually.
Were the inside wall visible to see if the modifications were more recent? The two homes I have in Santa Barbara are both from the 50's and look identical to this on the exterior. Both are lacking any drywall on the exterior walls.
Stephen Stanczyk
Old 2/9/11, 6:28 AM
Mr.Lambert.
Hard coat stucco falls within the definition of the 8 types of IFIS and its 3 subcatagories.
Here is a link to NACHI TV and the wonderful online courses it offers.
At 8 dollars a month you can not afford to NOT spend that pittens for such a large collection of residential knowledge in my view. .
Old 2/9/11, 11:10 AM
Tim Spargo's Avatar
Traditional hard coat stucco... the good ole' stuff, open stud bays/wire, paper and lath.
Recent (last 10-15 years) modification. Typical stuff.. no bolts @ plates where cut, no king studs (was on gable end, but hey!) and so on. Just your typical scabbed in door.
Robert, in our SoCal world, traditional / 3 coat stucco doesn't fall into the same definition of EIFS. By definition, we generally classify synthetics as those with a *different* base, such as foam core backing, polystyrene etc... A traditional / scratch / brown / finish type of stucco system does not gain the similarities or reputation of EIFS or synthetics.
Tim Spargo
661-317-5770
Old 2/9/11, 12:14 PM
Tim,
Sounds like just about every 1950's - 60's tract house down there. Now if you tell me there were snapdragons planted along that wall I will have a hearty laugh.
Stephen Stanczyk
Old 2/9/11, 12:35 PM
Tim Spargo's Avatar
sorry to disappoint, no snapdragons there.
"Updated and ready to move in Ranch Style Home"
All the snapdragons, olive green metal cabinets and appliances were all gone. $0.75 a square foot laminate and in-stock cabinets... badda bing!
Tim Spargo
661-317-5770
Old 2/9/11, 12:48 PM
Thanks for the update.
Lots of hard coat in Montreal also.
Just thought that good terminology was the bases for a proper narrative.
Never applied 3 step hard coat.
EFIS is the rage in Montreal seeing it has good insulation property's along with a better pricing and the many visual effects from crown moldings to signage that can be incorporated into the form.
Thanks.
Old 2/9/11, 1:09 PM
Shed some light for me on the "method" they used and apparently is common practice there. Why did they make the brick molding flush with the siding? Typically, the brick molding stands proud out away from the exterior wall surface. This makes it dang near impossible to make minor repairs for when the bottom of the door frame and the molding will rot out and makes the door look unfinished. Just don't know any better or don't give a fig?
- John Stuart Mill
Orange County Home Inspections whandley California Inspectors 12 5/18/11 6:35 AM
American Home Inspection Service Area jmckenna1 Miscellaneous Discussion for Inspectors 3 9/4/06 7:23 PM
