Old 5/6/06, 10:29 PM
Rafael Rafael is offline
Please Note: Rafael is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default exposed step flashing
Hi
Is there anything wrong with this flashing on the side of the roof here
being exposed . you can see that the siding being used as counter flashing does not go all the way down and cover the flashing. is this something you
home inspectors would right up and why?
Old 5/6/06, 10:38 PM
Default Re: exposed step flashing
I don't see a kickout flashing. Water can, and usually does, run behind the siding without it which is not good for obvious reasons.
Old 5/6/06, 11:20 PM
Carl A. Brown's Avatar
Step flashing being exposed can never be a good thing. Let alone as Larry said looks like no kickout diverter.
Old 5/6/06, 11:32 PM
gbeaumont's Avatar
Hi to all,
I would also have to take issue with the lack of kick-out flashing, but using the siding as a counterflashing is very common and acceptable. If the siding material is timber (which it appears to be in this case) then there should be a seperation of 1-2 inches between it and the roof covering to stop moisture wicking into the siding.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 5/6/06, 11:59 PM
Dale Duffy's Avatar
I agree with Gerry....but the siding looks like they measured once and cut twice....the first piece toward the roof eave anyway.
Old 5/7/06, 12:02 AM
Dale Duffy's Avatar
Rafael, are you short or are the Rose bushes 8 feet tall?.....
Old 5/7/06, 2:16 AM
Old 5/7/06, 8:39 AM
David P. Valley's Avatar
Originally Posted by gbeaumont
Hi to all,
I would also have to take issue with the lack of counter flashing, but using the siding as a counterflashing is ver common and acceptable. If the siding material is timber (which it appears to be in this case) then there should be a seperation of 1-2 inches between it and the roof covering to stop moisture wicking into the siding.
I concur...
Old 5/7/06, 11:32 AM
Steve Boozer Steve Boozer is offline
Please Note: Steve Boozer is a non-member guest and is in no way affiliated with InterNACHI or its members.
We always cut the siding off the roofline before we install new step flashing in the wall. The guide on the saw takes up 1 1/4 inches. This makes it easier to put the new flashing in. Looks better to use black flashing. Looks like there is no kickout and they didn't cut the siding even from top to bottom.
Old 5/8/06, 1:25 AM
Steven Brewster Steven Brewster is offline
Please Note: Steven Brewster is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nice install Steve. Wish more roofers would take more pride in their workmanship.
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 72 3/12/08 12:19 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 4:38 AM
Step flashing at vertical wall? jlybolt Exterior Inspections 31 2/12/06 12:40 PM
