Does anyone have some pictures of CMU house's being built in Florida in various stages of construction right upuntil the stucco is being applied?
Marcel, They need your self sticking BLUESKIN down there! imo "I create controversy whether they like it or not" |
What is wrong with just good old TAR PAPER-----
And a FLASHING-BREAK---- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
To easy!
It makes me sick, there is no such thing as a carpenter here that I know of, someone who can build a home which does not leak. All it takes is common sense, tar paper, and homemade flashing, installed correctly...no need for all the fancy, mancy, moisture barriers, etc. Don't even need caulk if it's built correctly. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
who doesn't know any better.... </IMG></IMG> |
CMU ?
Block "I create controversy whether they like it or not" |
No one has any pictures of phase inspections?
"All houses in Nova Scotia leak somewhere." I use that phrase in my self-generated "MOISTURE" appendix. This area has horizontal rain driven rains fairly regularly from fall through to spring |
Brian,
With the moisture moving to the cool side of the wall how can they not have moisture barrier on the CMU and not expect problems? With all the joint cracks in the CMU. Let alone the HVAC and the vacum it creates. "I create controversy whether they like it or not" |
| Bungalows to Mansions Professional Home Inspection, LLC | bgraham | Miscellaneous Discussion for Inspectors | 7 | 1/11/09 3:03 PM |
| Insurance-scarred Florida emigres stream to Atlanta | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 6/27/07 5:08 AM |
| TaxWatch: Florida Should Tax Internet Sales | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 4/7/07 2:42 PM |
| Gainesville,fl Alachua county Home Inspection | bgraham | Miscellaneous Discussion for Inspectors | 0 | 9/1/06 11:22 AM |
