Old 10/5/12, 10:17 AM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Default Exterior Step/Handrail Question
I did an inspection yesterday and the home had an interesting set of steps from the basement to the rear yard. My concern is the handrails, what do you all think? Does this look OK or should more handrails be added ?
Thanks
Jim
exterior-step-handrail-question-100_0893.jpg   exterior-step-handrail-question-100_0892.jpg
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
www.MarylandRadonTesting.org
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/5/12, 10:20 AM
jfunderburk's Avatar
jfunderburk jfunderburk is offline
Please Note: jfunderburk is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Exterior Step/Handrail Question
OK by me.
Old 10/5/12, 10:36 AM
Jeffrey R. Pope's Avatar
No additional railing is required. My only comment would be to the rail-end. It should be turned into the wall or blocked.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/5/12, 10:53 AM
Thanks Joe and Jeff. Good catch Jeff, I did note that.
Jim
Old 10/5/12, 11:00 AM
Bob Elliott's Avatar
Not a fan of the sloped landing up top.
Is that a trip hazard?
(see upper right ,1st picture)
Old 10/5/12, 11:08 AM
Its a big flat level concrete patio.
Jim
Old 10/5/12, 11:12 AM
Michael Larson's Avatar
Jim
I'd be more concerned with the lack of adequate fall protection around the stair well opening.
But that may not be an easy call.
Government is the great fiction, through which everybody endeavors to live at the expense of everybody else. -- Frederic Bastiat
Michael Larson
Hudson, WI
Old 10/5/12, 11:17 AM
BINGO, that was my original concern.
Old 10/5/12, 11:22 AM
Aren't the tops of all stairs usually open? That's what makes all stairs dangerous to some degree. If you want to be perfectly safe, sit in your room and don't ever go out of it. Life has risks.
Old 10/5/12, 11:56 AM
That's why I said it was not easy.
Yes stairs are dangerous but drop poorly protected drop offs even more so.
maybe you don't call out poor balcony guard rails either.
You tell me.
Michael Larson
Hudson, WI
Old 10/5/12, 7:56 PM
James T. McGrail's Avatar
James T. McGrail James T. McGrail is offline
Looks like a high gloss paint, might recommend 3M-Safety walk Treads
Old 10/12/12, 6:41 PM
Jim Hime Jim Hime is offline
www.stairways.org
Old 10/14/12, 12:50 AM
David Hays David Hays is offline
Out door amphitheater?
Get your tickets early, seats fill up fast!
David Hays
All Points Home Inspections LLC
Denver, CO
720-670-0366
allpointshomeinspect@yahoo.com
www.allpointshomeinspections.org
Old 10/14/12, 3:19 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
www.us.ecoglo.com.
There is also a small course I took on it in 2004.
For this application I would recommend it and a Railing in the middle.
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
apoteyes@gmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 10/14/12, 4:05 PM
Good point as we write up a 4.5 inch baluster gap while this is OK.
Four Point Inspection Question (Electrical) khunt Florida Inspectors 43 12/18/11 4:26 PM
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
Question for all... Bob Hopton-Jones General Inspection Discussion 9 4/6/07 7:43 AM
