http://s280.photobucket.com/albums/k...961/S%20-%20L/
A couple of the right tools sure would help it stick better if they were used right! ![]() ![]() ![]() The scarfire/scratcher is the preferred tool for the job but the notched trowel will do the same job and help keep it the same depth! Sure helps the Faux stone/glorified finish stick to the scratch cote and lath! ![]() Kickouts preferably the DRYFLEKT if not then one with sealed/folded seams that will kick the water out into the gutters and not down the face of the cladding sure would help a lot too! In this set of installation videos what do you see used for scratching/notching the wall so the stone will adhere better? http://www.canyon-stone.com/#/HOW-TO-VIDEO-06-00/ And in the pictures that are in the links do you see any scratch cote or kickouts,weepscreed,casing/66 bead around all of the edges for the backer rod and sealant joint? And the windows and FAUX wood trim are also improperly installed. "I create controversy whether they like it or not" Last edited by cbrown1; 11/13/11 at 5:27 PM.. |
| manufactured stone verbiage | bking | Exterior Inspections | 12 | 9/21/10 6:17 AM |
| Faux Stone! The next EIFS! | cbrown1 | Exterior Inspections | 35 | 2/18/09 7:51 PM |
| Cracking FAUX STONE | cbrown1 | Exterior Inspections | 23 | 1/23/09 10:24 AM |
| Faux stone siding | lfoster | Exterior Inspections | 15 | 11/5/07 7:40 AM |
| Expansion/ contraction joints | jlybolt | Structural Inspections | 13 | 5/31/07 6:03 PM |
