Old 5/12/09, 4:43 PM
Ron Chorey II's Avatar
Ron Chorey II Ron Chorey II is offline
Default Fire Place Chimneys
Is there any problem with chimneys being built this way. I have seen a few around town but this is my first house with this type of cover over the chimney flue. Thre are gas fireplaces, but there is a wood burner on the rear patio and a wood burner in an office.
fire-place-chimneys-picture-035.jpg   fire-place-chimneys-picture-043.jpg   fire-place-chimneys-picture-049.jpg   fire-place-chimneys-picture-036.jpg
Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America)
Old 5/12/09, 5:08 PM
Default Re: Fire Place Chimneys
What is it made out of? It it lined?
Larry Kage, CMI
231 929 3525
Old 5/12/09, 5:19 PM
Jeffrey R. Jonas's Avatar
From what I can see, it looks okay. I would just comment on the discoloration, and buildup that will likely occur. Annual maintenance strongly recommended.
Old 5/12/09, 5:41 PM
Built out of stucco
Old 5/12/09, 5:42 PM
I should say stucco wall cladding, probably wood underneath stucco
Old 5/12/09, 5:50 PM
I don't see a problem as long as the proper clearances to the chimney pipe are met. I suppose the lid over could effect the draft some...
Larry Kage, CMI
231 929 3525
Old 5/12/09, 11:24 PM
Jeffrey R. Pope's Avatar
Prefrabicated fireplace systems have sspecific requirements with regards to acceptable shrouds.
When you say gas, do you mean gas only, or does the "wood burner" share the same flue?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/12/09, 11:33 PM
Are we looking at concrete with stucco finish or are we looking at frame and synthetic (EFIS) surround and cap/cover? It looks like EFIS.
I'd be worried for gas logs operation, or/and especially woodburning operation if any is wood frame and EFIS finish.
The cap in 1st picture (diff. from 2nd & 3rd pic) looks like a good quality "airfoil" type, anti backdraft design cap, but looks pretty close to the stucco looking cap/cover.
I'll be interested in what you finally determine.
Old 5/13/09, 9:38 AM
The shrouds are framed in and then stucco'd. I can not tell the clearances as I could not get to the shrouds because of the tile roofing which I will not walk on because of the possibility of breaking the tiles. I have recommended a level II fireplace inspection by a qualified specialist about the clearances, which I do not know.
Please post questions about anything having to do with roofing kshepard Exterior Inspections 165 6/17/09 11:47 AM
Escape, Fire & Smoke Alarms badair Interior Inspections 14 1/28/08 7:21 AM
The Fire Guy ccrooker Canadian Inspectors 0 3/7/06 11:11 PM
