Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 5/7/09, 4:02 PM
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Flashing around windows
Would you say these windows were missing the J channel around the windows?
Thanks!
Find an InterNACHI certified North Dakota Home Inspector (and anywhere else in North America)
Old 5/7/09, 5:13 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Default Re: Flashing around windows
These windows have factory installed "J" channel on them. Its actually quite convenient to install. Nothing wrong.
Old 5/7/09, 5:21 PM
What is important is knowing how they flashed the windows. Most installers simply caulk and use a roofing gun to nail them in place. There is a certain way to flash or seal all windows......failing to do so even around these vinyl windows will cause problems later on.
Old 5/7/09, 6:10 PM
Doug Edwards,  CMI's Avatar
The Journal for Light Construction has an outstanding publication:
The JLC Guide to Moisture Control
This illustrates every kind of moisture control issue you are likely to see or run across during construction and renovations, remodeling. The book is very nicely done, not real expensive and slammed full of good photos and info. It is cheaper if you look around on Amazon rather than buying from JLC.
Doug Edwards, CMI
Old 5/7/09, 6:10 PM
But I can see the WET sheathing at the edge of the windows and some of the windows have J channels that you can see. I deferred this to a qualified siding contractor.
Thanks.
Old 5/14/09, 2:38 PM
Linda J. Foster's Avatar
Linda J. Foster Linda J. Foster is offline
Michael, how can a person tell by looking at that window that there is a J channel built in. What am I not seeing?
Thanks,
Linda Foster
www.HomeInspectionsByFoster.com
HomeInspectionsByFoster@yahoo.com
(210) 347-1023
TREC #7654
InterNACHI #06032691
Old 5/14/09, 8:08 PM
Thanks,
Linda, this is a picture of a window with an integrated J-channel:
But, Jeffery is right. It depends on how the installers flashed the windows that is important.
The flashing cannot be seen in the first post pictures but Buck saying he can see wet sheathing isn't a good sign.
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 5/14/09, 8:13 PM
David P. Valley's Avatar
I see these windows quite a bit here. It looks fine to me.
If it's not flashed correctly (which is not visible), it's not my problem.
Old 5/14/09, 8:20 PM
Originally Posted by bhartley View Post
But I can see the WET sheathing at the edge of the windows...I deferred this to a qualified siding contractor.
Thanks.
Good choice.
Sheathing (which is probably OSB) is not made to be wet and will turn into vertical mulch if allowed to be that way repeatedly.
Larry Kage
231 929 3525
Do you like Windows XP rcooke Canadian Inspectors 43 2/2/08 5:54 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior 6 10/13/07 9:10 AM
Free Office Software Eqiv. For Download bmerrell Misc. Discussion 4 12/31/06 12:47 PM
Self flashing windows jwilliams7 Exterior 21 11/16/06 3:58 PM
More water, different windows Brenda Exterior 12 9/22/06 3:55 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
