Old 2/12/09, 8:55 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Flashing over garage door
Would you recommend the area along the flashing and wood comp siding too be caulked? Water is standing on the flashing.The water is in contact with the wood comp siding.
Thanks!
Old 2/12/09, 8:59 AM
Default Re: Flashing over garage door
Would a picture help???
Old 2/12/09, 9:05 AM
David P. Valley's Avatar
Absolutely.
Is that Masonite siding?
Old 2/12/09, 9:28 AM
Bryce W. Jeffrey Bryce W. Jeffrey is offline
Flashing if installed correctly should direct the water away from the structure.
"Flashing installed incorrectly. Further evaluation required."
Old 2/12/09, 1:15 PM
Stephen W. Stanczyk's Avatar
LP lap siding installation instructions call for a 3/16" gap between the bottom course and the flashing. If you caulk this area, you are trapping any moisture in back of the siding and failure will result.
Chances are when the Z flashing was installed, they installed it with a 90 degree angle at the wall / trim junction. That is what causes the moisture to sit there. Proper installation would have the flashing installed with a slope to drain the water away. See attachment.
I see siding installed tightly on top of the flashing. I see the gap caulked. Report what you see.
Attachment 26855
Stephen Stanczyk
Old 2/12/09, 2:57 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Attachment 26855
I agree. I think the gap between bottom of siding and flashing should not be flashed (to allow water out if behind the siding) but a bead of caulk along the trim , under the drip edge, would be good.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 2/12/09, 3:12 PM
Robert J. Wind Robert J. Wind is offline
You no longer have to caulk the but joints of Hardie plank
Old 2/12/09, 3:21 PM
Unless they are field cut.
Stephen Stanczyk
Old 2/12/09, 3:24 PM
My comment was a but, not a butt
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 2/12/09, 3:30 PM
I had to call Hardie and ask. I inspected new Construction and every home was not caulked. Always something new.
OK, Butt
Old 2/12/09, 5:05 PM
Thanks!!!
Old 2/12/09, 5:19 PM
Doug Edwards's Avatar
Originally Posted by dvalley View Post
Absolutely.
Hi David,
It looks like Louisiana Pacific siding. It was involved in a large class action lawsuit since expired. The distinctive knothole pattern was the item used to identify it for the lawsuit. I still have some on my home in a couple of areas that I have slowly over the years replaced with Hardi. It is particleboard garbage, comes primed on the surface and completely exposed on the backside. Once it gets wet it becomes shredded wood chips, grows mold better than a pietri dish.
- John Stuart Mill
Old 2/13/09, 6:07 AM
This flashing is not sloped to convey the water away from the siding. Water will sit there and rot the lower edge of this siding.
Old 2/13/09, 6:09 AM
Originally Posted by dedwards View Post
Hi David,
That's what I thought.
I write this siding up as "High Maintenance Siding" and tell my clients to have it maintained annually.
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Automatic garage door openers..what are concerns? lfreeze Structural Inspections 8 5/18/07 10:38 AM
Garage Door Safety...No Reverse...Advice Please gliebig Exterior Inspections 33 3/17/07 7:28 PM
