Old 9/28/09, 7:42 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Flashing at stone
What would you say about this lack of flashing???
Thanks!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified Rhode Island Home Inspector (and anywhere else in North America)
Old 9/28/09, 7:48 PM
David P. Valley's Avatar
Default Re: Flashing at stone
I'm not sure what I'm looking at, but I see flashing atop the wood trim. The only other thing that should be done at this point is to seal the lower half of this trim with caulking.
Old 9/28/09, 11:59 PM
Unmoderated Guest
Well, this whole detail is a mess. I don't know how the same thing could be done with correct detailing. There needs to be flashing extending up behind the stucco and extending over the top of the stone, with weep holes. Ideally the face of the stucco and the face of the stone would be closer to the same plane. If the wood trim is absolutely required, I'd probably glue it to the stucco, and I'd make it 1 1/2 inches thick, to conceal more of the flashing, and hold its bottom edge up off the stone at least 1/4 inch.
Old 10/4/09, 11:51 AM
Sean Fogarty's Avatar
Caulk it. Caulking fixes everything!
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 10/4/09, 11:55 AM
Joe Funderburk, CMI's Avatar
That wood is bound to rot, in direct contact with masonry materials.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 10/5/09, 5:57 AM
What's wrong with utilizing duct tape there?
Old 10/5/09, 10:28 AM
Thanks!
That is a detail for future problems.
This detail would apply better for longevity.
http://www.onland.info/archives/2008...wlock_jm11.php
Old 10/5/09, 10:35 AM
mthomas2 mthomas2 is offline
If that's cultured stone, this is one recommended detail.
If you omit the water table the theory of the flashing system remains the same, you need a controlled exit form the stucco drainage plane above the cultured stone.
Old 10/5/09, 8:16 PM
You have flashing on top of the wood trim.
There is no through wall flashing at the stucco / brick.
Basically it looks like a code approved Kansas City Application.
Old 10/5/09, 11:16 PM
Yep!!!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Ledger Board Flashing jevans Exterior Inspections 15 7/2/09 10:42 PM
Graphic needed for flashing under stone work lfoster Exterior Inspections 8 8/2/07 10:54 PM
Expansion/ contraction joints jlybolt Structural Inspections 13 5/31/07 6:03 PM
no flashing; no inspection Leanne Jowers Exterior Inspections 97 5/9/07 12:11 PM
