Old 6/4/09, 9:13 PM
acassady's Avatar
acassady acassady is offline
Default Flashing verbage
I am looking for some verbage about these flashings....thanks
Find an InterNACHI certified South Carolina Home Inspector (and anywhere else in North America)
Old 6/4/09, 9:15 PM
mnahrgang's Avatar
Default Re: Flashing verbage
Flashing around the plumbing vents are damaged. Major Concern. Recommend repair/replacement.
Mark Nahrgang
www.HeyMark.info
Old 6/4/09, 9:47 PM
acassady's Avatar
Are they even installed correctly?
Old 6/4/09, 9:50 PM
Joe Funderburk, CMI's Avatar
"The commode plunger on the roof is probably leaking."
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/4/09, 9:54 PM
acassady's Avatar
Well the house was built in 1950 and had a nice remodel done on it and we have had some desent rain but there was no evidence of leaking
Old 6/5/09, 7:35 AM
dbolduc dbolduc is offline
Please Note: dbolduc is a non-member guest and is in no way affiliated with InterNACHI or its members.
It looks like snow and ice have been pushing against the boots, you are in MO so I suspect you do have these conditions from time to time. I can't tell from the pictures but this is a common problem in the north where many builders, architects, engineers, plumbers don't understand the fact that stacks must be installed close to the ridge or through an end wall when a metal roof is applied.
If this isn't the case in your area, it is an important factor for those in the land of snow and ice. I've seen many various types of stacks ripped off and damaged including a damaged smoke stack caused burn marks in attic space in a municipal garage which has been corrected. Be very aware of this situation.
Old 6/5/09, 8:26 AM
"Flashing has seen its better days..."
Old 6/5/09, 10:45 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Perhaps they should have used this....http://www.amsisupply.com/pipe%20fla...0hi%20temp.php
Old 6/6/09, 1:02 AM
[quote=jfunderburk;523362]"The commode plunger on the roof is probably leaking."[/quote
Vent flashing on the metal roof appeared to be of an improper type.
This condition may result in damage to home materials from roof leakage.
The inspector recommends correction by a qualified roofing contractor.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 6/6/09, 12:38 PM
acassady's Avatar
Thanks guys
Proper porch flashing? jfunderburk Structural Inspections 1 9/24/08 2:18 PM
Window flashing -- lfoster Exterior Inspections 42 10/28/07 10:47 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Graphic needed for flashing under stone work lfoster Exterior Inspections 8 8/2/07 11:54 PM
no flashing; no inspection Leanne Jowers Exterior Inspections 97 5/9/07 1:11 PM
