Old 4/26/11, 3:58 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default Flashing on wood deck
Would you call out a missing flashing on a ledger board installed directly on to the vinyl siding? I think the answer is yes because water can penetrate behind the ledger through the penetrating lag bolts and potentially broken siding. Thoughts?
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/26/11, 4:11 PM
Default Re: Flashing on wood deck
You answered you own question and I agree in calling it out.
Old 4/26/11, 4:34 PM
I was pretty sure that made sense. Thanks
774 Manor Road
718-514-3393
Old 4/28/11, 11:04 AM
Jeffrey R. Jonas's Avatar
I would also call out the ledger board applied over the vinyl siding. They installed it that way out of pure laziness to do it the right way. They assumed the vinyl would eliminate the need for the flashing. Or, they were just plain stupid. Flip a coin.
Old 4/28/11, 12:22 PM
Joe Funderburk, CMI's Avatar
Ditto. Installation over the siding is a defect.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/28/11, 1:36 PM
The proper way.
Old 4/28/11, 2:16 PM
William Warner's Avatar
William Warner William Warner is offline
The proper way.
Attachment 44350
That can't be proper... I only see it like that once or twice a year...
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 4/28/11, 2:46 PM
That's the way I build them, but also has a WRB not shown.
Old 4/28/11, 7:08 PM
Joseph Hagarty,  CMI's Avatar
ditto...
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 4/30/11, 9:47 PM
Ken Brittain Ken Brittain is offline
Please Note: Ken Brittain is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've heard that you can't use alum flashing with the new treated wood.
Old 5/1/11, 7:24 AM
You should not use Alluminum.
http://www.deckmagazine.com/article/188.html
Old 5/1/11, 7:34 AM
Preston L. Halstead Preston L. Halstead is offline
You are corrrect but when was the deck built. Before the changed treated lumber it was fine. Copper can be used
Preston L. Halstead
VP FL Home & Insurance Inspectors Chapter
Elite Property Inspection & Management
LICENSED GENERAL CONTRACTOR CGC1515203
LICENSED BUILDING INSPECTOR BN6262
LICENSED HOME INSPECTOR HI549
HOME INSPECTION ~ WIND MITIGATION INSPECTION
Serving Boca Raton, Boynton Beach, Delray Beach, Juno Beach, Jupiter, Lake Park, Lake Worth, Lantana, North Palm Beach, Palm Beach, Palm Beach Gardens, Royal Palm Beach, Wellington, West Palm Beach.
Old 5/1/11, 1:04 PM
Banned
The best details I have seen yet for deck-to-wall flashing is in the FEMA series for coastal construction..... I would recommend it for anywhere.:
http://www.fema.gov/rebuild/mat/mat_fema499.shtm
Factsheet #5.2
Old 5/1/11, 3:16 PM
Brian, here is the way deck ledgers and flashing is installed;
First a full SAF is installed on the exterior wall sheathing.
Then the ledger board is installed using GRK's structural screws into the floor framing joist.
http://grkfasteners.com/en/RSS_1_2_information.htm
Then another strip of SAF is installed over the ledger.
Then the ledger flashing is installed over the top of the ledger, (this one is plastic, but copper is available).
Finally, the WRB is drapped down over the flashing and sealed with the products seal tape.
In some cases, the ledger board and band joist are intentionally kept separated by a stack of washers on the lag screw or bolts to allow water to run between the two boards. In other cases, there is insulation between the two boards. Even worse is when the siding or exterior finish system was not removed prior to the installation of the ledger board. Situations like this, where the ledger board and band joist are not in direct contact, significantly reduce the strength of the ledger connection to the structure and are not recommended by InterNACHI, unless the two members are sandwiching structural sheathing.
The image above depicts washers being used as spacers between the ledger board and band joist, which is incorrect.
Now, if you were a Member of Inachi, you would know that, wouldn't you?
Old 5/1/11, 8:28 PM
Banned
Using sheathing tape in the above situation to seal the WRB to the drip edge flashing will probably not end up in a problem as you have the "belt & suspenders" working there with the Grace Vycor providing a 2nd seal under the flashing. I have seen it fail miserably when used to seal the WRB to the nailing flanges of vinyl and fiberglass windows. If you speak to the manufacturers about the WRB tape, they will tell you that it is only approved for use with their product.
Last summer I was in then city and drove by 20 year old upscale condos (~ $1 million/unit) at the edge of the waters here....it was being stripped on the outside- pine clapboard, TYVEK WRB, Tuck sheathing tape sealing the WRB to the vinyl windows- major water intrusion at windows and other trimwork leading to sheathing and minor framing rot.
The new stuff that was going back on was now using Flexwrap in the same manner to seal the new WRB to the vinyl window nail flanges.......I could already see failure beginning and the siding was not even installed! I took a few pictures for teaching purposes when the project manager came up and asked me what I was doing....I told him and .......mentioned that there was a very good detail from an article in JLC that was much superior to what was being done there.............of course, I was asked to leave the site!!
"In some cases, the ledger board and band joist are intentionally kept separated by a stack of washers on the lag screw or bolts to allow water to run between the two boards. In other cases, there is insulation between the two boards. Even worse is when the siding or exterior finish system was not removed prior to the installation of the ledger board. Situations like this, where the ledger board and band joist are not in direct contact, significantly reduce the strength of the ledger connection to the structure and are not recommended by InterNACHI, unless the two members are sandwiching structural sheathing."
Are horizontal boards considered structural sheathing?
The FEMA method does not use washers as spacers but a wood spacer (preservative treated I would hope).
One item I would improve is the bottom Z-flashing #1- I would like to see a 1/4-1/2" gap between the horizontal section and the bottom of the ledger board for organic debris cleanout. This is a great detail for a deck installation where there is siding below the ledger board as in the above INACHI diagram. It is usually quite hard to get a good seal there, so get the drainage water out and away from the horizontal joint.
Mold Resistant Wood by FrameGuard mcyr General Inspection Discussion 15 1/16/09 9:14 AM
Check The Deck wdevries Canadian Inspectors 1 7/9/08 2:00 PM
The Rise and Fall of CCA Wood Preservatives mcyr General Inspection Discussion 3 5/4/08 11:19 AM
Preventing Moisture related Problems mcyr Ancillary Inspection Services & Additional Topics 1 12/19/07 8:30 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
