I don't do commercial inspection but a friend asked me if it was normal to have insulation on top of the rubber membrane on a flat roof. It was built 20yrs. ago and today the insulation is so soaked that you can't lift it as it's too heavy. Personally, I've never seen or heard of a roof done that way. Sorry no pictures, has anyone heard or seen this.
Jeannot |
| Find an InterNACHI certified Oregon Home Inspector (and anywhere else in North America) |
Believe it or not it is the truth. I am talking about a hospital roof, when the snow melts I will get some pictures.
Jeannot |
Is it foam with gravel on it? Foam like in Styrofoam
Yes I will check and read your link this afternoon
thank Jeannot |
Inverted roof system.
Water proof membrane first, insulation then applied on membrane, a separation barrier over the insulation and then finally aggregate or other form of ballast to cover that. When the separation barrier deteriorates or is torn the water gets down and soaks the insulation. Some installations may not even have it since it is only recommended. According to some roofers and manufacturers this is not a problem unless the water proof membrane is exposed to the elements. Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
Anyone have pictures of this type system?
Water as been leaking in the building for some time now This building is not more than 30 yrs old, I thing there looking into a new roof. Jeannot |
Can be apllied to 2 3 and 4 ply and I also think motified btm |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 7:31 AM |
| Flat Roof / Rubber Roof | Susan Rogers | Exterior Inspections | 3 | 3/18/08 1:34 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 1:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
