Old 12/17/07, 7:52 PM
Ronald G. Chorey II's Avatar
Ronald G. Chorey II Ronald G. Chorey II is offline
Default Flat roof question
Ran into a flat roof that appeared to be a built up roof that was 3 ply. My question is there was no 90 weight on it or gravel. What was used was a silver reflective coating. Is there a problem with a roof like this? See pictures
flat-roof-question-hpim1008.jpg   flat-roof-question-hpim1009.jpg   flat-roof-question-hpim1010.jpg
Old 12/17/07, 7:56 PM
apolillo's Avatar
apolillo apolillo is offline
Please Note: apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Flat roof question
I see them all the time. They might not last as long in NM as Baltimore without the covering. Just look for signs of ponding when you see this type of roof. Of course, all the flashing is covered.....
Anatol
Old 12/17/07, 8:03 PM
David P. Valley's Avatar
Ronald,
Looks good to me. It's simply a fibered reflective coating. Inspect for split seams, transition areas, flashing at roof penetrations and ponding (as Anatol stated).
Old 12/17/07, 8:04 PM
Dale Duffy's Avatar
Ron,
Looks good from here...from your pictures anyway.
Same way they install most flat roof systems here.
Old 12/17/07, 8:39 PM
Don't they believe in vertical surfaces and cant strips down there?
I guess they don't believe in a straight line finish for stucco to flashing termination.
No ponding on that roof, scuppers will do it. Thank god if the three ply could handle ponding even less the framing underneath.
Man some of these roofs scare me. ha. ha.
Jesus, Dale, I am getting worse than you. Picky, picky, picky,
Marcel
Old 12/17/07, 9:03 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ron the flashing in your third picture looks irregular to me at the parapet wall.
How was it installed.
Old 12/17/07, 9:13 PM
Dale Duffy's Avatar
This one ponds a little water here and there......
Old 12/17/07, 9:18 PM
Dale Duffy's Avatar
Here is the Guts of the same type of installation with a little destructive testing......
Old 12/17/07, 9:40 PM
relliott's Avatar
Lovely Dale.
Carl A. Brown's Avatar
Dale posted a picture with lath instead of chicken wire.
The world must be coming to an end!
Old 12/17/07, 9:44 PM
They could have at least ran caseing bead on the bottom to get a good clean line. Astm would like to see weepscreed.
Old 12/17/07, 11:53 PM
Barry Adair's Avatar
just a little morning dew and some really suck***** roofing
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/18/07, 12:02 AM
Dale Duffy's Avatar
Yeap---that's bad "Bear"....!!!!.....
Old 12/18/07, 12:06 AM
This one among other things killed the multi-M deal
We'll be doing another prop. very soon
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 12/18/07, 12:09 AM
relliott's Avatar
Barry , did someone paint the bitumen?
Roof question mashburn Exterior Inspections 23 12/16/07 8:14 PM
No access to roof... staylor5 Exterior Inspections 20 3/10/07 8:14 AM
Wood shake roof question jclark1 Exterior Inspections 4 9/11/06 10:23 PM
Moss growing on roof ecox1 Exterior Inspections 43 1/19/06 10:57 PM
