What is the recommended height of the flue coming out of the chimney?
There is a screen over this chimney, for birds. Attachment 19742 "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com Last edited by nbhi; 7/8/08 at 8:41 AM.. |
Are you referring to the "liner," or an exhaust system of other sorts? That looks like an unlined masonry chimney. Can't really tell from your photo.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 3/21/08 at 10:29 PM.. |
Jeff
Not sure if it is lined. Was unable to see from the roof. Furnace and watertank vent into this. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
They don't need to extend out of the chimney. . .
Jeff
Would you recommend rain cap? Brain in post#2 says 2 to 4 inches? "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
I always recommend a rain/weather cap. Even here in sunny CA.
When I encounter a chimney that is not accessible from the roof (Like this one) I take a picture at the access door in the basement. (If there is one and if I can open the door) When I get home I can enlarge the photo to try to determine if there is a flue.
The chimney pictured appears to have been rebuilt at the top. They should of extended the flue so they can install a proper cap. If higher efficiency appliances are venting up this chimney it will deteriorate again. This chimney may require a liner & cap depending on what type of furnace is installed. This would be beyond our scope of an inspection. I just wouldn't want to be responsible if there was an unlined chimney. |
Here's a representation of a good masonry chimney: http://www.maconline.org/tech/constr...y/chimney.html I noticed this US org was calling the crown a chimney cap also. Last edited by Brian A. MacNeish; 3/22/08 at 10:44 AM.. |
| Flue through bedroom closet | rwills | Interior Inspections | 7 | 2/1/08 6:40 PM |
| How many gas/oil appliances can vent into 1 flue? | jberthiaume | Inspecting HVAC Systems | 11 | 10/17/07 10:09 AM |
| Cracked flue tile | bknowlton | Inspecting HVAC Systems | 6 | 2/1/07 11:37 PM |
| Flue Size when size matters? | msylvester | Inspecting HVAC Systems | 14 | 1/20/07 11:29 PM |
| Gas Log Flue venting height. | lagudo | Inspecting HVAC Systems | 34 | 4/7/06 1:42 AM |
