Old 9/25/08, 12:19 AM
Brian E. Kelly's Avatar
Default Foam Roof + Woodpeckers
Nice, I like the way they tried to pop the blister.
Old 9/25/08, 12:35 AM
Dale Duffy's Avatar
Default Re: Foam Roof + Woodpeckers
Old 9/25/08, 11:31 PM
jkogel jkogel is offline
What you get for building with stucco and foam - mutated woodpeckers.
Some of those holes could be from Dale's pellet gun.
Old 9/26/08, 12:12 AM
gbeaumont's Avatar
Isn't picture 3 from "Myst or Riven"? I keep clicking on it but nothing happens
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 9/26/08, 7:15 AM
Carl A. Brown's Avatar
Woodpeckers like EIFS.
Stucco will damage their peckers!
Old 9/26/08, 8:15 AM
tmcnamara tmcnamara is offline
Typically roofs will "peel up" or "blow off" in the corners first since that is where the greatest forces of wind uplift occur. Tht's my guess as to what those holes are in the corner of the roof.
The 3rd picture looks like a blister probably due moisture in that particular spot that heated up and expanded into the bubble.
Ted McNamara
President
Builders Roofing and Supply, LLC
P.O. Box 170831
Milwaukee, WI 53217
Builders Roofing and Supply, LLC is the exclusive distributor of GutterStuff in the USA and Canada.
866-766-3442
GutterStuff Rebate Coupon for Internachi Members and their Customers:
http://www.gutterstuff.com/internachi
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Question about exposed styrofoam insulation. mlong Exterior Inspections 9 12/21/07 8:33 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
